Head gasket problems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by your nightmare, this thread has received 31 replies and been viewed 15331 times.
post #1 of 32 (permalink) Old 01-06-2010, 04:25 AM Thread Starter
Redneck with some Bling
your nightmare's Avatar
Images: 1
Has anyone heard of any one needing a head gasket yet? I have about 75k and my cooling system is under pressure all the time and if I get on it it dumps all coolent into overflow tank I am going to try my best to get done under waranty but dont think it will happen any ideas for upgrades while I have the head off? I think I will put head studs in
Thanks
2007 Dodge 2500 Mega cab Laramie fully loaded (love my heated seats in the winter) 6.7L
Banks cold air intake w/super scoop techni-cooler
wishing someone would steal my DPF Holly crap it fell off the other day
EGR stealth kit on
SMARTY OMG love it
6" stacks
Klienn Train horns 156.9db Get out of my way or you will pee yourself
HID projector headlights Custom grill with 7" EURO lights ("can you see me now")
37x14.5x20 NITTO TG HELO rims
6" TGC W/ pure porformance long arm kit
6" ATLAS rear springs
Rides like a 1500
to all military members MARINE
http://www.youtube.com/watch?v=9jYwzk-G4Q8
http://www.youtube.com/watch?v=Dx3Qkjljk4o
your nightmare is offline
post #2 of 32 (permalink) Old 01-06-2010, 04:48 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
I have heard of guys needing gaskets wit smarty but....studs would def be smart while its off.
Military Quote Of The Year
SOOTBANDIT is offline
The Following User Says Thank You to SOOTBANDIT For this addition to TDG:
your nightmare (01-06-2010)
post #3 of 32 (permalink) Old 01-06-2010, 05:11 AM Thread Starter
Images: 1
I was on SW 7 and just came back from a very long road trip almost 2k miles and was not getting on it at all heat just stoped working and coolent all over the fenderwell just praying ther are no other things wrong no oil in coolent and no coolent in oil
EGR stealth kit on
SMARTY OMG love it
6" stacks
Rides like a 1500
post #4 of 32 (permalink) Old 01-06-2010, 06:39 PM
PhilipR's Avatar
I'd O-ring it to unless something has changed with the 6.7 vs the 5.9 is that department.
-Phil-
PhilipR is offline
The Following User Says Thank You to PhilipR For this addition to TDG:
post #5 of 32 (permalink) Old 01-06-2010, 07:18 PM Thread Starter
Images: 1
do you use the o-rings with a gasket or do they replace the gasket? never been in a 6.7 or 5.9
EGR stealth kit on
SMARTY OMG love it
6" stacks
Rides like a 1500
post #6 of 32 (permalink) Old 01-06-2010, 09:17 PM
fuzzy's Avatar
External waste gates seem to be helping with the HG problems. It seems to be caused from to much drive pressure. Smarty and XRT seem to be getting the blame, so my smarty has been set to sw1, and I try to keep the boost under 30. Not always easy dragging 22k. Studs would be good, but I've also read of it still happening with arp 625's. Still lifting the head. The EWG controls the drive pressure to a 1:1. I've read that some guys with a guage have seen as much as 2:1 which I guess is bad. Most of this is a little beyond my knowledge, and I'm just relaying what I've read about the issue.
fuzzy is offline
The Following User Says Thank You to fuzzy For this addition to TDG:
your nightmare (01-07-2010)
post #7 of 32 (permalink) Old 01-07-2010, 02:09 AM
ADMIN/MAFIA
neeltburn's Avatar
I am beginning to wonder if deletes are the way to go? Fuzzy your camper weighs close to what ours weighs. What kind of boost press are you seeing with SW3 and SW1? I am getting closer to pulling the trigger, but after a leaky CP3 and reading about HGs blowing I am leaning to the unpopular decision to keep my power train warranty. Also what kind of Boost press is causing HG issues? I have seen as high as 25-29psi stock.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #8 of 32 (permalink) Old 01-07-2010, 12:49 PM
PhilipR's Avatar
With O-rings you use the stock gasket. Fire-Rings are a whole different story and really not good for street trucks.
-Phil-
PhilipR is offline
your nightmare (01-10-2010)
post #9 of 32 (permalink) Old 01-07-2010, 02:30 PM
Inline Junky!
Sledpuller500's Avatar
Images: 121
This is an O-ringed 5.9 head that is currently on my truck. You can see that the Rings are laid into the head right at the fire ring area. It basicaly adds more material to the fire ring area and makes it harder to blow out. It also creates a tounge and grove effect on the fire ring preventing them from moving!
Sledpuller500 is offline
The Following User Says Thank You to Sledpuller500 For this addition to TDG:
post #10 of 32 (permalink) Old 01-07-2010, 05:02 PM
fuzzy's Avatar
Neel, you can easily keep the boost under 30 pulling 11-12k. I can still get going pretty good pulling 22k with the boost holding 28-30 psi. The HG issues have had me just a little concerned, but at the same time there is not enough of them to completly throw the blame on the tuners. Most of them I've read about are from guys that run the living dog snot out of their trucks day in and day out.
fuzzy is offline
neeltburn (01-07-2010)
'98 Dodge 12v Head studs and Head Gasket PhilipR Supporting Vendors Forum 2 10-09-2009 10:20 AM
Head Gasket Head Studs?? BrianHonda629 2003-2007 6.0L Power Stroke 15 09-29-2009 11:31 PM
Hypermax Head Studs and Head Gasket HotSauce2138 Supporting Vendors Forum 11 04-28-2008 04:40 PM
Head Gasket time should I stud it and A/M Gasket it? cdooguy 2003-2007 6.0L Power Stroke 7 04-26-2007 04:36 AM
Head Gasket Problems???? NEED HELP pullnpowerstroke 2003-2007 6.0L Power Stroke 3 08-27-2005 01:10 AM
