More power with EGR/DPF Delete ??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by $trokin60, this thread has received 15 replies and been viewed 14037 times.
 1Likes
post #1 of 16 (permalink) Old 02-22-2010, 01:20 AM Thread Starter
Does deleting EGR and DPF give more power, or better fuel milage, or a combo of both. I am installing a 6.7 in my harley truck and dont need them since my truck is a 2004.
2004 Black over Orange F-250. C/C 304 MBRP turbo back exaust. powertrap air filter(by Wix/Visteon).
SLAPS (St. Louis Area Powestrokes) Member.:Thumbup:
$trokin60 is offline
post #2 of 16 (permalink) Old 02-22-2010, 03:32 AM
ADMIN/MAFIA
neeltburn's Avatar
It frees up power and a better breathing engine is going to get better MPG.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 16 (permalink) Old 02-22-2010, 02:06 PM
Proud Texan
madville's Avatar
Deleting the DPF will only free up some more power, I've heard more than a few times that doing the EGR/EGR Cooler deletes actually causes you to lose a few horses. I didn't really notice that much of a loss on mine, that's just some rumors I guess.
Scooter
2008 Dodge Ram QC CTD 6.7L
Performance: Magnaflow straight 5" TBE, Industrial Injection Hybrid VGT, S&B CAI, H&S Performance XRT, Shibby EGR/EGR Cooler delete.
Exterior: Recon Smoked Cab lights, Windows tinted, Spray-in bedliner, Black nerf bars
Interior: Putco LED Dome lights, Alpine IVA-W505 Headunit, Marathon Realtree Camo Seat Covers
American Club #17
Singles Club #0
madville is offline
post #4 of 16 (permalink) Old 02-22-2010, 03:08 PM
Let it all Ride
Eazydeezy's Avatar
I've never heard about the power loss with the EGR delete, but your not gonna gain any power by doing it. But your engine will thank you for deleting it as you won't have exhuast running back through your engine. Doing a DPF delete will give you more power.
Dominic
Eazydeezy is offline
post #5 of 16 (permalink) Old 02-22-2010, 04:15 PM
Skyd Ram's Avatar
Deleting the EGR will help the most with mileage and keep your engine clean. If you just unplug it wihtout any electronics you will get a code and it had shown a drop in power. Deleting the DPF won't help much for power or mileage but it will get EGT's down and get rid of the possible clogged dpf. When you add a delete tune like the XRT,BlackMaxx,Smarty,Smarty JR, or the upcoming new Eclipse tuner from Vengeance Performance, you will seriously wake the truck up.
You should consider doing some ARP 425 head studs before the motor goes in and possibly a EWG kit.
chainesm likes this.
2010 CCSB Laramie Ram 2500 4x4
Powered By:
H&S/Shibby/Black Ops/Flo Pro
Suspended by:
Carli Suspension/Bilstein
2008 RCLB F250 XLT 6.4 Auto
Powered By:
H&S/Flo Pro/aFE
Suspended by:
Pure Performance/Carli/Bilstein
Skyd Ram is offline
post #6 of 16 (permalink) Old 02-23-2010, 01:40 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
When i dynoed my truck wit just 4in tbe, clutch, edge set to 0, cai i made 327hp 598ft/lbs this was wit just block off plates in the egr cooler was still intact. But as Ram said studs or just go ahead and put a aftermarket turb on it would be best
Military Quote Of The Year
SOOTBANDIT is offline
post #7 of 16 (permalink) Old 03-01-2010, 01:24 AM Thread Starter
was planning on doing head stud, jus not sure which one to go with. was also kicking around the idea of balancing the rotating assembly. Skyd Ram what is an EWG kit?
post #8 of 16 (permalink) Old 03-01-2010, 01:54 AM Thread Starter
(Exaust Waste Gate) from the way I understand it the stock turbo can flow plenty air but doesnt scavenge well do to a restrictive exaust housing. Does this kit just dump excessive exaust overboard?
post #9 of 16 (permalink) Old 03-01-2010, 04:04 AM
Skyd Ram's Avatar
The VGT turbo that this motor uses can create drive pressure ratios in between 2 to 1 and 2.5 to 1. Even with some of the milder tunes this can create drive pressures approacing 60 psi. This is a contributing factor to blown head gaskets and can also hamper power in the upper rpms. The EWG can be set to open as the pressures increase to lower the drive pressure.
Powered By:
Suspended by:
Powered By:
H&S/Flo Pro/aFE
Suspended by:
Skyd Ram is offline
post #10 of 16 (permalink) Old 03-01-2010, 11:48 PM Thread Starter
thanks for all the help. Skyd Ram when I was building powerstrokes I liked the H 11 tool steel head studs from A 1 fasteners. are the ARP 425 strong enough? Also is the stock turbo sufficiengt for 400 to 500 rear wheel HP or am I better off changing to a diffrent turbo?
Edge Juice, EGR Delete,SCT, Wheels & Tire, Liberator Egr Delete 760 PSD Whats Been Sold 3 04-22-2008 09:45 PM
cat-delete or muffler-delete Dual K20s 5.9L Cummins (2003-2007.5) 20 09-06-2007 09:49 PM
Cat delete robs low end power? ALBOB 2003-2007 6.0L Power Stroke 13 06-27-2007 06:37 AM
03-06 6.0L Cat Delete/Muffler Delete dfuser Supporting Vendors Forum 1 04-08-2007 09:07 PM
need a muffler delete pipe, and pushy pipe delete ~CrazyDiesel~ 2003-2007 6.0L Power Stroke 13 03-31-2006 11:56 PM
