Time to change CCV at 67505mi - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SOOTBANDIT, this thread has received 11 replies and been viewed 3705 times.
post #1 of 12 (permalink) Old 02-23-2010, 03:23 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
http://www.genosgarage.com/prodinfo.asp?number=CV520010
Just got off the phone wit Casey at [email protected] and explained to him i had a perform service message on the overhead but no cel and he said it was the CCV that is plugged and needed to be replaced and it just so happened to come on as i hit 67500mi exactly so i got on genos garage and found a replacement filter to get this changed. Who else has had to do this yet? Seems pretty simple just ontop of the valve cover assembly. If anyone would like i can take pics and make a write up on it cause if it has not been changed ill almost bet it will at 67500mi
Military Quote Of The Year
SOOTBANDIT is offline
post #2 of 12 (permalink) Old 02-23-2010, 03:36 PM
Let it all Ride
Eazydeezy's Avatar
I had to do it on my old rig bud. Very easy to do...
Dominic
Eazydeezy is offline
post #3 of 12 (permalink) Old 02-23-2010, 03:42 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
sweet
post #4 of 12 (permalink) Old 02-23-2010, 09:17 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Well i got it reset for now till my new filter gets here.
Steps to reseting the overhead
1. Turn key to on position
2.Fully depress brake pedel 2x
3.Fully depress accelerator 2x
4. Turn key to off postion
Should reset then if not repest steps.
post #5 of 12 (permalink) Old 02-23-2010, 09:29 PM
Dodgefarmer's Avatar
My truck also had the Perform Message come on exactly at 67500 miles. The manual also says the egr cooler needs to be cleaned also. I know its not an issue for those who have done the egr delete but I am still stock. I asked my dealer about it and told me not to worry about it. They have never done it and feel it is a greater risk to get some leaks from opening it up and cleaning. As long as its running fine don't bother, so I did not do it. Now at 72000+ miles. BTW have not changed the CCV yet.
singles club # 198
Dodgefarmer is offline
post #6 of 12 (permalink) Old 02-23-2010, 10:00 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Really well ill be a SOB so you are over and never had it changed hummm i have been deleted for damn near 50k and no issues so i wonder if i need to actually change it or not..? Its $60 guess it wouldnt hurt to change anyone elses input would be greatly appreciated
post #7 of 12 (permalink) Old 02-23-2010, 10:44 PM
It's a good idea to change that filter out even before the 67500 miles. That filter gets full of oil that could get sucked down in to your turbo and then to your inter cooler.
2008 Dually Quad Cab, 6 Speed Auto 3.73, Edge W/Attitude,21/2" Hell bent Leveling Kit, Firestone Airbags, DIY Step Bars,EGR Delete, 4" Turbo Back Exhaust From K-2 Diesel, Cummins Mud Flaps,ATC Topper and Rhino lined rockers front to back
Rev. is offline
post #8 of 12 (permalink) Old 02-23-2010, 11:53 PM
Maybe I will pull it and look at it sometime just for curiosity
singles club # 198
post #9 of 12 (permalink) Old 02-23-2010, 11:55 PM
Its only $
singles club # 198
post #10 of 12 (permalink) Old 02-24-2010, 12:45 AM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Well the Bentley said not to waste my money on one till it comes back on again said it wont bother a thing
Oil Change TIME Interval brendonv 1994-2003 7.3L Power Stroke 15 08-22-2009 02:14 AM
A must see... Time to change Paul Ray The Parking Lot 2 03-21-2009 01:45 PM
Time for an oil change. GilroyRacing 1994-2003 7.3L Power Stroke 14 08-02-2007 12:24 AM
Time for an Oil Change NonHemi 2003-2007 6.0L Power Stroke 14 10-17-2006 09:45 PM
time to change the fuel filters SSpeeDEMONSS 2003-2007 6.0L Power Stroke 33 08-25-2006 02:28 AM
