water/methanol injection - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by eby94, this thread has received 11 replies and been viewed 2436 times.
post #1 of 12 (permalink) Old 02-26-2010, 01:50 AM Thread Starter
Hey guys, I have posted here before and yall have helped out every time. We drive our truck mainly on the weekends and sometimes pulling a very heavy horse trailer. My egt's get very high when pulling the trailer on acceleration up to highway speeds or pulling hills (1350 +/-). I always back out of it until they go down, has anybody done water injection and which one is the best. I am concerned because I will have to install my dpf to pass emissions and remove it again. A lot of work, but it is worth it to me.
2007 3500 4x4
6.7l
dpf delete
egr delete
edge/attitude
eby94 is offline
post #2 of 12 (permalink) Old 02-26-2010, 04:41 PM
HLC2239CUMMINS's Avatar
What setting you run on the edge when getting this hot? The 6.7 can take some heat but you should be a little cooler with all your deletes. I have never used water meth but from what I've heard that should fix your problem.
2010 6.7 cummins 4x4 crew cab short bed 6 speed auto 4:10 gears stock for now. Draw tite brake controller
HLC2239CUMMINS is offline
post #3 of 12 (permalink) Old 02-28-2010, 01:10 AM Thread Starter
when towing, I run on level 2. I have never run any higher than level 2. I always back out of it when the alarm goes off, it is set at 1350.
2007 3500 4x4
6.7l
dpf delete
egr delete
edge/attitude
eby94 is offline
post #4 of 12 (permalink) Old 02-28-2010, 07:42 AM
pre or post turbo?
cummins907 is offline
post #5 of 12 (permalink) Old 02-28-2010, 11:45 AM Thread Starter
pre turbo
2007 3500 4x4
6.7l
dpf delete
egr delete
edge/attitude
eby94 is offline
post #6 of 12 (permalink) Old 02-28-2010, 02:12 PM
ADMIN/MAFIA
neeltburn's Avatar
Have you thought of trying an aftermarket intercooler? that could also reduce your EGTs a bit.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #7 of 12 (permalink) Old 02-28-2010, 06:42 PM
even an intake or larger boost tubes would do it. that is cheaper. or that boost fooler? havent tried that one though, has anyone?
post #8 of 12 (permalink) Old 03-01-2010, 02:17 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Boost fooler isnt going to lower that much wit out supporting mods. Where you located altitude??? How heavy is this horse trailer? Getting up to highway speeds witout high egts on these trucks is not going to happen wit a heavy load witout lots of air. I pulled my buddys 09 2500 cummins back from denver to cheyenne at 80mph and my edge was on level3 and my power puck was at 25-30% and egts would get up high coming on to the interstate but cruising it was a consistant 1000-1100egts. So either get a aftermarket turbo to pull big loads or as some have stated intercooler, boost tubes, and maybe try out the boost fooler i only got maybe 25-50* cooler MAYBE.
Military Quote Of The Year
SOOTBANDIT is offline
post #9 of 12 (permalink) Old 03-01-2010, 04:32 PM
every little bit helps though
post #10 of 12 (permalink) Old 03-01-2010, 04:41 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
well depending how fast he trying to get to watever speed is as factor you cant expect to move a 8000lb truck and watever the 4 horse trailer loaded down ways HEAVY from 20mph to 65 or 75 mph on a on ramp or expect to pull 15k+ up a mountain at highway speeds and maintain under 1300 egts not going to happen. get more air before more air on these 6.7 and you will have way lower egts
Water/Methanol Injection 03RescueDiesel 2003-2007 6.0L Power Stroke 15 07-22-2007 09:09 PM
Water Methanol injection 1911 Guy 5.9L Cummins (2003-2007.5) 1 02-19-2007 04:18 PM
Water/Methanol Injection? medicbaldwin 5.9L Cummins (2003-2007.5) 8 02-19-2007 09:41 AM
Water/Methanol Injection anyone? Racertow 2003-2007 6.0L Power Stroke 0 01-26-2007 06:58 PM
water/methanol injection [email protected] 7.3L and 6.9 IDI (Pre 1994) 0 05-05-2006 05:29 PM
