Truck started cutting out HELP! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kwik06ctd, this thread has received 8 replies and been viewed 2554 times.
post #1 of 9 (permalink) Old 03-17-2010, 03:05 AM Thread Starter
My 05/09 6.7 with manual trans has started to stumble at low rpm, after every shift or just starting out. Feels like it is trying to stall. Sometimes soft sometimes hard, warm or cold same diff. Just rolled over 13k miles and never been in regen no codes, it just feels weak. Oil changed 3 times(mobil syn and mobil filter), fuel filter(Napa) changed once, no other work done. 5000 pound trailer feels a lot heavier than it did with my 5.9. HELP!
kwik06ctd is offline
post #2 of 9 (permalink) Old 03-17-2010, 02:41 PM
HLC2239CUMMINS's Avatar
does it pick up after it gets through it's stumble ? any chance of a boost tube off or a loose clamp ?
2010 6.7 cummins 4x4 crew cab short bed 6 speed auto 4:10 gears stock for now. Draw tite brake controller
HLC2239CUMMINS is offline
The Following User Says Thank You to HLC2239CUMMINS For this addition to TDG:
kwik06ctd (03-19-2010)
post #3 of 9 (permalink) Old 03-19-2010, 04:51 AM Thread Starter
Runs fine after that first little sputter/buck, I've been through all the hoses, my first thought was maybe i left something loose the last time i pulled the intake to change the oil filter. I' m wondering if the new fuel filter may have something to do with it. The local napa didn't have a gold filter, just the cheap one. I'm starting to think that it may not like the B20 that I've been running. I'm on my second tank of regular #2 with no addative and I think it feels a little less noticeable.
post #4 of 9 (permalink) Old 03-20-2010, 03:25 AM
stillcrazyinlaw's Avatar
Images: 3
I don't know about the truck but we run bio at work and the filters in our pumps need changed alot more often than with reg #2
stillcrazyinlaw is offline
The Following User Says Thank You to stillcrazyinlaw For this addition to TDG:
kwik06ctd (03-20-2010)
post #5 of 9 (permalink) Old 03-20-2010, 09:35 PM
now i don't have a cummins but i have a ford 6.0 and i have had the same problem before one thing to check which worked for me was the fuel filter. i know you said you changed it but i too changed mine with a napa filter and same problem when i took it back out and compared it to the manufacture's filter it was a about an 1/8 inch shorter. i went down to the stealership and bought all new oil and fuel filters and wouldn't you know it. problem solved both oil and fuel filters were out of spec from napa. oh and they were acutually cheaper than napa. you might want to compare. but before you spend the coin also check all your clamps on your boost tubes and the tubes themselves for holes are a split in the rubber tube. hope you get back running strong. cheers!
midnightcaper is offline
The Following User Says Thank You to midnightcaper For this addition to TDG:
kwik06ctd (03-21-2010)
post #6 of 9 (permalink) Old 03-21-2010, 05:26 PM Thread Starter
Makes sense to me, and i am going to give some factory filters a try. The trouble didn't start until after the new fuel filter. Its amazing what effects filters can have on these new trucks. I had the same type of trouble with my wifes liberty CRD. It was cutting out and bucking, the dealership said it was tranny and programing issues. They actually had another one on a lift with the tranny out and some kind of patch kit going in allong with a reflash of the computer to follow. I wasn't sold. The problem started after the first oil change, so i bought a factory oil filter and compared to the one that was on the jeep, and it was different. the small holes on the factory unit were sealed after market was not. I installed the new filter and problem solved, don't ask me how, but it worked. 80K trouble free miles and counting. Thanks for the reminder!
post #7 of 9 (permalink) Old 03-21-2010, 10:53 PM
Hope all is well with the new filter. Let us know !!!
kwik06ctd (03-22-2010)
post #8 of 9 (permalink) Old 03-24-2010, 02:14 AM
any updates with the factory filter?
post #9 of 9 (permalink) Old 03-25-2010, 11:57 PM
You still running ? Diesel down ? Or what ? Don't leave us hanging
Truck started then almost died 05fx4 2003-2007 6.0L Power Stroke 12 06-04-2009 12:34 AM
Got Brents Truck Started BogginF350 2003-2007 6.0L Power Stroke 99 05-13-2009 04:14 PM
truck cutting out Orangepstroke 1994-2003 7.3L Power Stroke 4 05-03-2009 02:39 PM
truck started Robts 2003-2007 6.0L Power Stroke 10 03-20-2008 10:29 PM
truck cutting out french_12 1994-2003 7.3L Power Stroke 3 01-12-2008 01:57 AM
