Fuel rail plug????? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by goatman1419, this thread has received 3 replies and been viewed 2926 times.
post #1 of 4 (permalink) Old 03-22-2010, 05:36 PM Thread Starter
Fuel rail plug?????
I just ordered the xrt tuner egr delete and dpf delete turbo back to the muffler. The guy at H&S said I may need something called a fuel rail plug????Anyone heard this or has one, I never read anything about it so interested to see if I really need it Thanks.
goatman1419 is offline
post #2 of 4 (permalink) Old 03-22-2010, 06:19 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
More than likely you will need the plug or the rail will have to be shimmed like mine real easy to do. Just to keep your fuel release valve closed untill higher psi that way it dont open at lower psi.
Military Quote Of The Year
SOOTBANDIT is offline
post #3 of 4 (permalink) Old 03-23-2010, 02:02 PM
Proud Texan
madville's Avatar
I actually have a friend here whose truck was built a month after mine and has the same flash as I do. Mine is shimmed from when I had the MP-8 on, and his isn't. They put the 60 hp tune on it(Same as mine) and the truck sounded absolutely horrible. I don't know if it caused any damage, but he had a shim kit waiting just in case. Hardest part about shimming it is to be careful to not lose the small pin. Other than that, it takes like 30 minutes tops to do.
Scooter
2008 Dodge Ram QC CTD 6.7L
Performance: Magnaflow straight 5" TBE, Industrial Injection Hybrid VGT, S&B CAI, H&S Performance XRT, Shibby EGR/EGR Cooler delete.
Exterior: Recon Smoked Cab lights, Windows tinted, Spray-in bedliner, Black nerf bars
Interior: Putco LED Dome lights, Alpine IVA-W505 Headunit, Marathon Realtree Camo Seat Covers
American Club #17
Singles Club #0
madville is offline
post #4 of 4 (permalink) Old 03-30-2010, 02:11 PM Thread Starter
Well ordered the fuel rail shim kit the plug wasnt going to be in stock untill 4/10 didnt want to wait THANKS GUYS.
Fuel rail pressure? slow23bj 2008-2010 6.4L Engine Tuner Forum 2 07-22-2009 11:58 AM
LLY Fuel Injection Fuel Rail Assembly Replacement - Bank 1 ripmf666 GM Spec Info 0 12-28-2008 11:38 AM
LLY: Fuel Injection Fuel Rail Assembly Replacement - Bank 2 ripmf666 GM Spec Info 0 12-28-2008 11:37 AM
LLY: Fuel Injection Fuel Rail Assembly Replacement - Bank 1 ripmf666 GM Spec Info 0 12-28-2008 11:24 AM
fuel supply psi or rail psi? catdude 5.9L Cummins (2003-2007.5) 8 05-03-2007 04:53 AM
