Egr Delete with Smarty Jr. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by neeltburn, this thread has received 11 replies and been viewed 11948 times.
post #1 of 12 (permalink) Old 03-25-2010, 10:23 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
I have My Smarty Jr., EGR blocker plates and 5in exhaust. (everything is here except 5in TBE) My question is can I just unplug the throttle valve and cooler servo motor and put my blocker plate in the cross over tube. Mads EGR instructions I know I need to take the actuator spring out of the egr valve. but do I need the big plate for the intake horn or can I just bolt the egr valve motor back on, and hook the cross over tube back up? This is the only part that is a little fuzzy. That and how you unhook for sensor lines from the truck. any help would be great.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #2 of 12 (permalink) Old 03-25-2010, 11:53 PM
HLC2239CUMMINS's Avatar
Wow ! Looked at those directions for mads are way different than the one i had. I left the servo assembly alone and plugged in. Had egr block off plate took off the egr valve assembly clear off added 2 plates. Pulled off the intake horn took the 2 screws out for the throttle valve plate pulled plate out put the horn back on and was good to go ! 2 of the intake horn bolts can be a pain also. Wounder why they just don't take the egr valve assembly off and use the blocker plates. Hope any of my ranting helps. I have 2 spare erg valve assembly blocker plates (free) if you want them let me no. I ain't doing anything to this for a while. There just sitting on my tool box. Read more into the directions now i see why the egr valve stays i loaded my smarty for no egr or dpf and got full power from it . GOOD LUCK !!!
2010 6.7 cummins 4x4 crew cab short bed 6 speed auto 4:10 gears stock for now. Draw tite brake controller
HLC2239CUMMINS is offline
post #3 of 12 (permalink) Old 03-25-2010, 11:56 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Im leaving the motor for the egr valve hooked up but I will be tieing it up out of the way and will be putting the blocker pate I bought (already) on it. I think I have it figured out.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #4 of 12 (permalink) Old 03-25-2010, 11:59 PM
post #5 of 12 (permalink) Old 03-26-2010, 01:39 AM
fuzzy's Avatar
That's how mine is and what I would reccomend. Not sure if your talking about the pressure sensor lines or what, but I took mine off at the pressure sensor. The electrical to the pressure sensor stays hooked up. Unplug the throttle body valve on the back side. I also unplugged the servo on the cooler, but I don't think that really needs to be done.
fuzzy is offline
post #6 of 12 (permalink) Old 03-26-2010, 03:14 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Yeah Im pretty much following the egr delete instructions I posted expect using a blocker plate on the intake horn and hanging the end on the motor as mads instructions say.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #7 of 12 (permalink) Old 03-26-2010, 03:36 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Another question, should I download the ME tune before I start removing parts, and putting the new ones on?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #8 of 12 (permalink) Old 03-26-2010, 01:33 PM
Let it all Ride
Eazydeezy's Avatar
I would, that way you're ready to go as soon as your done with the deletes!
Dominic
Eazydeezy is offline
post #9 of 12 (permalink) Old 03-26-2010, 01:44 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Dont be afraid of sticking the 130 in just for a cruise around your block or street for a seat of the pants feeling just wat it can do.
Military Quote Of The Year
SOOTBANDIT is offline
post #10 of 12 (permalink) Old 03-27-2010, 03:13 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
No 130 tune just a 40, 70, 100 hp.... gonna start at either 70 or 40 prolly 40 since I have some towing to do. IT GOES DOWN TOMORROW!
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
Delete ?s /Smarty?s neeltburn 6.7L Cummins (2007.5-2011) 43 03-18-2010 02:30 AM
Smarty DPF Delete? Rich 6.7L Cummins (2007.5-2011) 3 05-27-2009 03:17 AM
Edge Juice, EGR Delete,SCT, Wheels & Tire, Liberator Egr Delete 760 PSD Whats Been Sold 3 04-22-2008 09:45 PM
cat-delete or muffler-delete Dual K20s 5.9L Cummins (2003-2007.5) 20 09-06-2007 09:49 PM
03-06 6.0L Cat Delete/Muffler Delete dfuser Supporting Vendors Forum 1 04-08-2007 09:07 PM
