Its Done - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by neeltburn, this thread has received 9 replies and been viewed 1684 times.
post #1 of 10 (permalink) Old 03-28-2010, 03:53 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Its Done
So Deletes are done, Smarty Jr. is installed on 40hp (mileage) and Im loving it. Not sure anything is pic worthy yet, But the ol seat of the pants dyno says it done right now. Thanks to everyone here a TDG for their help and encouragement, I now no longer miss my 24v 5.9 (2k1 cummins) My truck is now MINE! thanks guys, Ill try and post a video if its not raining to hard tomorrow. Next of is trying the 70 hp tune (towing). Currently Im running SW1 (40 hp) Torque Management on 1 and Timing set to default. I will report mileage as it goes.
Dom, Brandon, Kenny
Thanks For your help!
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #2 of 10 (permalink) Old 03-30-2010, 06:25 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Anytime man glad your loving it told you that you would how is that 5in tbe STAINLESS treating ya??? I bet its sweet sounding
THIS THREAD IS WORTHLESS WITHOUT A VIDEO
Military Quote Of The Year
SOOTBANDIT is offline
post #3 of 10 (permalink) Old 03-30-2010, 07:04 PM
Let it all Ride
Eazydeezy's Avatar
I'm pretty stoked you got this done! Good work!
Dominic
Eazydeezy is offline
post #4 of 10 (permalink) Old 03-30-2010, 10:12 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Did your guys truck coolant temps run lower? I mean My EGTs a cut almost in half and my coolant temp dropped 10-15*, I can see where the engine would run much cooler if the EGTs are dropped that much, does this sound normal?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 10 (permalink) Old 03-31-2010, 02:18 AM
fuzzy's Avatar
the mia egr will make it take longer for the truck to warm up on cold mornings, and i suppose could result in lower temps, but my truck usually runs 190-200.
fuzzy is offline
The Following User Says Thank You to fuzzy For this addition to TDG:
neeltburn (03-31-2010)
post #6 of 10 (permalink) Old 03-31-2010, 02:20 AM
fuzzy's Avatar
oh and congrats on the new again truck!! like a different animal now isn't it?
fuzzy is offline
post #7 of 10 (permalink) Old 03-31-2010, 03:47 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
I tired making a video tonight (with straight 5in) but it was to dark, Ill work on that tomorrow evening.
Yes Fuzzy it is even better than it was! (no that it was ever bad, except for the warranty BS) It is going to get a muffler sometime this week. and yes fuzzy it runs about 185-190ish but with an almost 400* drop in EGTs I would expect it could run a tad cooler like maybe 5-10* cooler. the real test will be once the 5er (toyhauler ) is hooked to it. Should I be scared to bump the timing to 1 or should I leave it at default where it is now? Torque Management is on 1 and I really like it there. not to sure if I want to change that? Thanks again Guys
PS Kenny Thanks again for all the help You Rock!
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #8 of 10 (permalink) Old 03-31-2010, 03:56 AM
TDG Mafia Goon
BombDocDiesel's Avatar
Congrats Neel!
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #9 of 10 (permalink) Old 03-31-2010, 02:22 PM
Let it all Ride
Eazydeezy's Avatar
Neel, you'd be fine bumping the timing up. That being said, I would hook the 5'er up and test it out and see what you like the best. Now I wouldn't ramp the smarty up and jump all the torge management settings up, but you know that.
Dominic
post #10 of 10 (permalink) Old 03-31-2010, 10:00 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Torque Management will Stay on one, I may move timing to 1 as well. Still testing the 40hp tune, then I will move up to 70hp with tq1 and maybe timing 1.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
