intermittent check engine light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rtrolli69, this thread has received 7 replies and been viewed 1466 times.
post #1 of 8 (permalink) Old 04-03-2010, 02:01 AM Thread Starter
Angry intermittent check engine light
Well hey need some info.Dealer didnt fix it yet. I keep getting a intermittent check engine light and truck throws the code p2121.they reset it. reflashed computer,then next time said they changed accelerator pedal position sensor. Week later same thing. The truck runs fine but if it comes on sometimes it wont accelerate or I have to let off and then reapply the gas pedal. It will be on when I pull it in the garage,then next morning when I start it its gone?Sometimes it will go a month or sometimes two no trouble? The last few weeks more frequent on & off. Still under warranty but its my only vehicle and hate it at the dealer.Any info?
rtrolli69 is offline
post #2 of 8 (permalink) Old 04-03-2010, 11:42 PM
buffalobob's Avatar
mine kept doing that and the dealer replaced egr valve, then the o2 sensor. finally i replaced the batteries and it all went away. one was weak and causing voltage fluctuation on cold mornings. service managwer didnt believe me when i told him it fixed the problem. hasnt come back on in 6 months.
2011 silverado lt, crewcab, short bed, 4X4, d-max/ allison
buffalobob is offline
post #3 of 8 (permalink) Old 04-04-2010, 03:19 PM Thread Starter
Thanks for the info,I think I will have them tested.Took a road trip yesterday about 200miles and the light went off,has not come back yet? maybe some hwy driving put a good charge on them?interesting!
post #4 of 8 (permalink) Old 04-04-2010, 08:31 PM
buffalobob's Avatar
i had read on one of the forums about voltage effecting the computer. i asked the service manager straight up itf that could possibly be my problem. he was very definite that it was not the problem. his words." no. if there is enough voltage to light the lights, the computer will work" guess he dont know much about computers. didnt mind having to buy my batteries, but 5 trips to the dealership 70 miles each was a little irritating.
post #5 of 8 (permalink) Old 04-07-2010, 03:23 AM Thread Starter
well tested batteries today they were both ok.So what to do now?
post #6 of 8 (permalink) Old 05-24-2010, 05:08 AM Thread Starter
Well here is an update,truck has still been doing this off&on for months.pull it in the garage w/cel on, next morning fire it up, back out its gone??!! Dealer had truck for several days,they did the J35 recall,also changed the throttle pedal position sensor again...still same result. usually happens in the morning on the way to work,short drive.1 morning im driving to the dealer & rpm is @ 1500.. then it would just drop to an idle you could push the pedal to the floor & hold it truck wouldnt accel at all??! I get there leave truck running ask them to drive it,now they say it acts up and the trble is n the harness?? This doesnt sound good! I mean if its not the sensor its either the wiring or Computer right? Im just worried its my first new truck.... any help would be greatly appreciated!
post #7 of 8 (permalink) Old 05-26-2010, 01:55 PM
first off the light going away after you restart is normal on newer vehicles, there are some codes that will stay on but not usually.
2007.5 Ram 3500 4x2 QC
6 speed manual
Edge Attitude with/ Juice
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Egr and Egr Cooler delete
Black Tec Mafia #19
BigRed6.7CTD is offline
post #8 of 8 (permalink) Old 05-27-2010, 04:07 AM
mdcody101's Avatar
Sounds like you have a throttle valve sticking from carbon build up
mdcody101 is offline
check engine light jordan_labelle 2003-2007 6.0L Power Stroke 1 01-22-2010 12:57 AM
Check engine Light because of air box Baldguy5.0 2008-2010 6.4L Engine Tuner Forum 11 12-06-2009 12:22 AM
#08-06-04-054: Snow Intrusion into Air Cleaner, Check Engine Light On, Engine Reduced ripmf666 GM TSB Info 0 08-10-2009 04:46 AM
Check engine light blackcloudCTD95 5.9L Cummins 12 Valve (1994-1998.5) 2 07-10-2007 01:49 AM
check engine light imported_hotrod 1994-2003 7.3L Power Stroke 10 03-13-2006 09:01 PM
