Service required on overhead - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fjwill, this thread has received 6 replies and been viewed 12314 times.
post #1 of 7 (permalink) Old 04-05-2010, 02:07 PM Thread Starter
Question Service required on overhead
I have service required see dealer now on overhead. Truck has smarty and turbo back exhaust with the EGR blockers in place. Truck runs great no coeds, just want to get it to stop dinging all the time. anyone no how to get rid of this i would greatly appriciate.
fjwill is offline
post #2 of 7 (permalink) Old 04-05-2010, 02:21 PM
stillcrazyinlaw's Avatar
Images: 3
have you tried the thing that clears oil change required on the overhead. turn key on and depress accelerator pedal 5 times to the floor.
stillcrazyinlaw is offline
post #3 of 7 (permalink) Old 04-05-2010, 07:51 PM
HLC2239CUMMINS's Avatar
My 07 did that once. It would not clear with the clear dtc's so i reloaded the smarty program and it went away. Might be worth a try.
2010 6.7 cummins 4x4 crew cab short bed 6 speed auto 4:10 gears stock for now. Draw tite brake controller
HLC2239CUMMINS is offline
post #4 of 7 (permalink) Old 04-06-2010, 12:58 AM
Dodgefarmer's Avatar
By chance did it come on at or close to 60,000 miles?
If so it is for egr cleaning. I asked my dealer about it and and they said they have never cleaned one, in fact I was about the only one that asked about it. They told me to clear the warning and not to worry about it. They had more concerns about causing leaks etc by opening it up vs. leaving it alone if all was working fine.
Its been 16,000 additional miles since I cleared the warning and have had no problems
singles club # 198
Dodgefarmer is offline
post #5 of 7 (permalink) Old 04-06-2010, 01:58 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Knew a guys that did that and then he sold the smarty and xrt never has acted up might be worth a shot! ok that was mean im sorry...are you running sims still along the exhaust? If so try taking them out and blowing them out could ahve some sirt or moisture in them. Does it white/blueish/greyish smoke ever?
Military Quote Of The Year
SOOTBANDIT is offline
post #6 of 7 (permalink) Old 04-06-2010, 07:27 PM Thread Starter
52,000 miles on truck cleaned the EGR it was easy it is laying on my work bench. I think it is a meassage to go to the stealership for some checking account abuse. All i want is to clear it. the dingging chime is annoying.
fjwill is offline
post #7 of 7 (permalink) Old 04-06-2010, 09:57 PM
ADMIN/MAFIA
neeltburn's Avatar
Try this:
PERFORM SERVICE INDICATOR - RESET
Unless reset the “Perform Service” message will display on the EVIC each time you turn the ignition switch to the ON/RUN position to indicate a emission maintenance is required. To reset the “Perform Service” indicator system (after performing the scheduled maintenance) refer to the following procedure:
1. Turn the ignition switch to the ON position (Do not start engine).
2. Press and release the brake pedal two times.
3. Fully depress the accelerator pedal slowly two times within 10 seconds.
4. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illumination when you start the vehicle, the “Perform Service” indicator did not reset. If necessary repeat this procedure.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
Diesel Additives required? BCMC 6.7L Cummins (2007.5-2011) 10 01-25-2008 04:04 AM
The required first post jserfas Introductions 4 12-19-2007 09:10 PM
Thought Required King of Obsolete Medium and Heavy Duty 10 09-23-2007 03:07 PM
Oil change required light Brutus the Grey 6.7L Cummins (2007.5-2011) 8 08-21-2007 04:12 AM
Time Required?? Extended Power 2003-2007 6.0L Power Stroke 3 12-10-2006 07:40 PM
