Help?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jlake, this thread has received 13 replies and been viewed 1494 times.
post #1 of 14 (permalink) Old 04-12-2010, 07:32 PM Thread Starter
jlake's Avatar
Images: 2
Help??
Beleive i lost a head gasket on my 09 6.7 pushin antifreeze out the puke tank gonna pull head tonight does anyone know of a machine shop near akron-cleveland area that can o-ring it for me if i go that route 330-807-3873 or call with tips questions or suggestions not happy here edge set to stock smarty on level 1 mild tune for this to happen use truck to pull trailer usually round 13k not enought to make it push out a gasket i beleive
2009 3500 dually; FLO-PRO 5' TURBO BACK NO MUFFLER,EDGE ATTITUDE W/JUICE,WEISS EGR DELETE,SMARTY W 15 ME SOFTWARE==
jlake is offline
post #2 of 14 (permalink) Old 04-12-2010, 10:56 PM
ADMIN/MAFIA
neeltburn's Avatar
Not 100% sure but I believe that the timing levels in 14me and possibly 15me had Higher timing levels, 20 me is supposed to have much less timing in it. Right now with my jr I have timing set to default(maybe still paranoid) Could be your issue, but I wouldn't think it caused it towing unless you hot roding it cold.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 14 (permalink) Old 04-13-2010, 01:56 AM
HLC2239CUMMINS's Avatar
How many miles ?
2010 6.7 cummins 4x4 crew cab short bed 6 speed auto 4:10 gears stock for now. Draw tite brake controller
HLC2239CUMMINS is offline
post #4 of 14 (permalink) Old 04-13-2010, 12:16 PM Thread Starter
jlake's Avatar
Images: 2
26 k on it
jlake is offline
post #5 of 14 (permalink) Old 04-13-2010, 12:24 PM
Originally Posted by jlake View Post
26 k on it
Ouch !!!
post #6 of 14 (permalink) Old 04-13-2010, 01:13 PM
PhilipR's Avatar
Give Karl at Redline Diesel a call....He's right off US 71 in Burbank just south of Medina.
http://www.rdpdiesel.com/index.html
-Phil-
PhilipR is offline
The Following User Says Thank You to PhilipR For this addition to TDG:
jlake (04-13-2010)
post #7 of 14 (permalink) Old 04-13-2010, 01:49 PM
Let it all Ride
Eazydeezy's Avatar
Are you running your smarty with your edge tuned up too? If so, that could be a serious problem.
Dominic
Eazydeezy is offline
post #8 of 14 (permalink) Old 04-13-2010, 01:58 PM
ADMIN/MAFIA
neeltburn's Avatar
Originally Posted by Eazydeezy View Post
Are you running your smarty with your edge tuned up too? If so, that could be a seriuos problem.
Did you have juice timing on and run a smarty odd SW? if so that is way to much timing. If you are running them stacked you need to either turn juice timing off or run a even SW on the Smarty... Stacking tuners you have to be very careful.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #9 of 14 (permalink) Old 04-13-2010, 03:39 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Smarty man i dont mean to harp but to many 6.7s having HG issues running this...Did your edge have a seperate option on it to turn the edge timing off and have a stock timing option? If not and you just set it to level zero then that could seriously be your issue cause turning it to zero(stock setting ) does not turn off timin all the way. Im sorry to hear this man are you for sure going to o ring it? Def get studs put in while its off especially if your going to continue running that smarty even wit it being on sw1. Take that Edge completly off and buy guages if thats what you were using it for dont even consider putting it back on and running again but i know you wont do that. Last thing BUY XRT!!!
Military Quote Of The Year
SOOTBANDIT is offline
post #10 of 14 (permalink) Old 04-13-2010, 07:20 PM
Let it all Ride
Eazydeezy's Avatar
Honestly man, I haven't heard of anybody blowin head gaskets on a mild tune with a Smarty. But ramp any programmer up and stack it, and your just increasing CP's too much with out studing it. I have never been a fan of stacking programmers though.
Dominic
