08 Batteries question. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by allscott, this thread has received 5 replies and been viewed 1088 times.
post #1 of 6 (permalink) Old 05-06-2010, 07:19 PM Thread Starter
So I went to start my truck yesterday and it turned over once and then stopped. I haven't driven it in a couple of weeks.
It was acting like a dead battery so I put the charger on it over night and tried again this morning. Still nothing. I checked both batteries at lunch and one is at 10V and one is at 11V which I found odd since I just assumed the batteries were in parallel?
So my question is, is there anything else that could be wrong other than my battery charger not working? I used it a couple of months ago on my car and it worked fine. Also its been hovering here around the freezing mark for the last couple of weeks. Could I have wrecked the batteries if they were dead and it was that temp.
And finally is there anything in particular a person needs to know about charging/ boosting a truck with two batteries?
Thanks in advance.
allscott is offline
post #2 of 6 (permalink) Old 05-06-2010, 09:17 PM
Dodgefarmer's Avatar
Thanks in advance.
Does your charger have a amp or volt meter to see if it is actually putting out a charge? Pull both bats and have them check with a battery tester. Might have a bad cell in one bat.
singles club # 198
Dodgefarmer is offline
post #3 of 6 (permalink) Old 05-06-2010, 09:54 PM Thread Starter
Unfortunately no, it just has a meter that shows percentage of charge and it is showing that the batteries are almost fully charged which they obviously are not.
The truck is still under warranty so if it is something more complicated then just simply my charger isn't working I'll just call the dealer and they can deal with it.
Thanks.
allscott is offline
post #4 of 6 (permalink) Old 05-08-2010, 03:28 AM
ADMIN/MAFIA
neeltburn's Avatar
If I were to bet, you have a dead cell in one battery and it being bad took the other one with it.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #5 of 6 (permalink) Old 05-10-2010, 09:54 PM
easy money's Avatar
get a 7.99 solar charger for harbor freight tools keep in plugged in when your not using the truck......problem solved .....that' plus tax
1995 f250 2wd PSD, auto, DIY intake, DIY exhaust, PHP tuned 40hp tune , Hybrids injectors 238cc..... 13.618 in the 1/4 at 6000lbs.
1995 GMC 3500HD dump truck 6.5 turbo(lol) DIY intake and exhaust.
2008 GMC 2500 hd stock for now.EFI LIVE installed!!!!!
easy money is offline
post #6 of 6 (permalink) Old 05-10-2010, 11:34 PM
be careful about anything that may be staying hot, causing a major drain, if it is really hot or as in your case really cold is usually when batteries tend to take a crap, the other major killer is temp variation.
2007.5 Ram 3500 4x2 QC
6 speed manual
Edge Attitude with/ Juice
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Egr and Egr Cooler delete
Black Tec Mafia #19
BigRed6.7CTD is offline
The Best Set Of Batteries?? Stroker01 1994-2003 7.3L Power Stroke 28 06-18-2009 06:52 PM
batteries question utlonghorns416 2003-2007 6.0L Power Stroke 18 06-08-2009 04:17 PM
Batteries? hccumminssmoke 5.9L Cummins (1998.5-2002) 18 02-06-2009 07:16 AM
Batteries gone bad Diezel Dawg 1994-2003 7.3L Power Stroke 11 01-06-2009 03:12 PM
Question about jump starting a truck with dead batteries. Truckie Medium and Heavy Duty 8 10-16-2006 01:33 AM
