MP 8 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sstockton, this thread has received 16 replies and been viewed 1326 times.
post #1 of 17 (permalink) Old 05-10-2010, 03:14 AM Thread Starter
MP 8
I just scored an MP 8 off of a buddy, and was wondering what you guys thought about these. He said that it didn't seem to raise EGT's or rail pressure to a dangerous point at all. I don't have gauges on my truck yet, which I want to do pretty quick here, so I will probably wait until I have those to plug it in. But I was just curious what you guys think. Should I run a rail pressure gauge with this, or just make sure to have a pyro on there. Do any of you have experience with them?
Nothing came up when I searched for it. Also, how do you think my stock clutch will take it? I can get a south bend Dual disk at an exceptional price if I want it, but I am not sure if that is too much clutch, as I don't plan on really modding this truck.
Thanks in advance,
post #2 of 17 (permalink) Old 05-10-2010, 09:14 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
I have played wit my power puck alot same thing as your mp8. I also didnt notice much change in EGT's when the xrt was off wit just the puck turned up. I get the most power i believe out of it around 70-75% all the way up is a waste. If you can get a DD i would get the 3250 pedel pressure on mine is less than stock pretty much real smooth enguagement for a DD amd very street friendly i have over 50k tuned on mine hauling and running up an down the street
Military Quote Of The Year
SOOTBANDIT is offline
post #3 of 17 (permalink) Old 05-10-2010, 05:29 PM Thread Starter
I will look into it and see if it is the 3250 or the 3600. A friend of mine has the 3600 on his 07 5.9 and says that he hates it. But that is a pretty serious clutch, I am looking for something that will do alright with minimal mods and hold up to towing a fair amount, maybe 9-10k.
post #4 of 17 (permalink) Old 05-10-2010, 05:41 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
I love my 3250 pedal is just like stock (no BS) idk why he hates the 3600 i drove one thye just a little stiffer. Well its worth the money if you add a tuner,exhaust for piece of mind that your clutch will hold up for past the life of the truck. mine has been in for roughly 60k and no problems i slipped it good one night let it sit over night all was well
post #5 of 17 (permalink) Old 05-10-2010, 07:05 PM
BigBlueDodge's Avatar
I have a MP8 on mine i like it alot. Never had any problems at all with it. Give good power when im towing and little better gas milage. Id put it on dont need to worry about rail pressur or anything. HEy Bandit i ran the 120 tune over the moutian with that trailer and it ran awesome. Got fifteen miles to the gallon up and like twenty back down. FREakin awesome
07 6.7
6 Inch lift
37-13.50 Nitto Mud Grapplers
XRT WOOO
Ts-mp8
S&B Intake
5 inch to 7 inch mitter cut stacks
egr all gone
2 10 inch mtx subs
Tint
Boost Fooler
Black Head and Tail lights
BigBlueDodge is offline
post #6 of 17 (permalink) Old 05-10-2010, 08:18 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Nice man i knew you would like it. I only use the 60 if its a BIG load lol mainly 120 mild turbo and puck at 75% it is badazz good smoke show if i load it up
post #7 of 17 (permalink) Old 05-10-2010, 11:44 PM
i like mine but i have had a few issues but I am thinking they are lift pump related. all in all they are great for mileage and decent power gains just don't expect magic to happen, expect a 2-4 mpg increase and yes some smoke!
2007.5 Ram 3500 4x2 QC
6 speed manual
Edge Attitude with/ Juice
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Egr and Egr Cooler delete
Black Tec Mafia #19
BigRed6.7CTD is offline
post #8 of 17 (permalink) Old 05-11-2010, 12:40 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Wat problems you run into?
post #9 of 17 (permalink) Old 05-12-2010, 02:54 PM
Well anytime I have it on and just lay into the throttle it will drain the fuel rail which has led me to believe the lift pump can't keep up. The rail has a replacement plug in it rather than shimming the original one. I have checked the plug to make sure from ts that it is the correct replacement and it is so, the only thing i can think of is the lift not keeping up.
6 speed manual
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Black Tec Mafia #19
post #10 of 17 (permalink) Old 05-12-2010, 03:06 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
that weird i drained 1 time wit my edge/puck but wit the xrt/puck i have never drained you get any codes? Do you run edge on 6 and puck at 100% all the time?
