Give me opinions and info... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tm0231009, this thread has received 25 replies and been viewed 2171 times.
post #1 of 26 (permalink) Old 05-22-2010, 03:52 PM Thread Starter
TDG MAFIA #101
tm0231009's Avatar
This should be fun...I am loking for the opinions and info from the guys that drive the trucks. Before long our road district will be looking for a new truck and I wanted to know the ups and downs of all of the new trucks. I am going to ask this from Ford, Dodge, and GM. Tell me anything you might think would be helpful in our search to find the right truck for the money. We would order a 1 1/4 to 1 1/2 ton truck regular cab, DRW, 4x4, Auto or Manual (I like the 2011 Fords with the auto/manual, but I don't know much about Dodge or GM either). The truck pull probably 10-12K everyday, plow snow during the winter, and sometimes idle all day and during the winter all night too. There have been times that they have ran for two days without being turned off. So they do get pushed a little but, but are taken very good care of mechanically and cosmetically. Which brings me to another point, maintenance on the trucks...how hard is it to work on the newer ones. Guys thanks in advance for all of what you have to offer, and I really don't want it to turn into something like don't buy dodge because I drive a Ford, I myself am a ford guy, but the 6.7 dodge's at the shop are laying the beat down to the 6.0 Fords. Not saying that I would like to see the fords take back over or anything like that I am just saying I would like to hear everyones views.
On the hunt for a 7.3 preferably CC or Ext. Cab SB...Let me know of any deals.
1979 Ford F-100 Ranger, Custom dark purple and silver paint, 15"x8"117 Series Eagle Alloy's, Winston tires, 400 cu - Work In Progress!! http://www.cardomain.com/ride/2570291
"The only dumb question is the one not asked."
TDG MAFIA MEMBER #101
TDG SINGLES CLUB MEMBER #88
tm0231009 is offline
post #2 of 26 (permalink) Old 05-22-2010, 06:29 PM
buffalobob's Avatar
i have had chevy( 94 model diesel before duramax), ford 02 powerstroke (7.3l) and dodge. 12v, 24v, 5.9 crd, and 08 6.7. the chevy was most comfortable. and engine i had was no problem. but not as powerful as new models and not around any more. ford likewise not around any more. but it was the most reliable of the fords. dont know much about fords newest engine. 6.7l v8. but was talking to mechanics and service foreman in locakl ford dealership. they said 7.3 good. 6.0 stay away from. and 6.4 passable. they were concerned about the aluminum heads on an iron block. stated that different expansion rate could cause problems. and if the 2011 ford iss like the 6.4's you have to remove the cab to do much work on them. the dodges i have had were all very reliable. never an engine issue. dodge isnt as comfortable as ford or chevy. i currently have 08 dodge 6.7. no problems except had to replace batteries at 50K miles. i guess my choice of dodge over chevy and ford is an inline 6 over a v8. also chevy with a japanese engine. but other than multiple problems with the 6.0 ford all seem good choices.
2011 silverado lt, crewcab, short bed, 4X4, d-max/ allison
buffalobob is offline
The Following User Says Thank You to buffalobob For this addition to TDG:
tm0231009 (05-28-2010)
post #3 of 26 (permalink) Old 05-23-2010, 05:25 AM
Hydro's Avatar
The 2011 Ford does Not require cab removal to work on the engine. As far as aluminum heads on iron..... the Duramax should answer those questions, meaning it's a non issue.
Hydro is offline
The Following User Says Thank You to Hydro For this addition to TDG:
post #4 of 26 (permalink) Old 05-23-2010, 05:07 PM
Also the block on the 6.7 ford is not iron its grafite.
2006 yamaha Vmax
2003 suzuki 1000 GSX-R
1993 F-250 460
Near GP alberta.
CC#58
budtoh3zo is offline
post #5 of 26 (permalink) Old 05-23-2010, 07:05 PM
I Eat Rice
forcefed6.4ford's Avatar
Accually Dave the block is Iron with grafite in it. Think of it as high carbon steel but for cast iron. This results in a weight savings of 150lbs for the block with an increase of 50% for strenght and rigidity.
The heads are aluminum. High heat transfer and also another 70lbs weight reduction. These head should the cats azz. Less chance of warpage of heat/stress cracking from high load applications. ie plowing. Plus more responsive driving characteristic due to the reverse flow heads and the single sequential turbo.
As for comparing dodge/chev/ford for plowing aplications. There is no denying the capabilities of the ford compaired to the other 2 manufacturers. The Ford have a tough front end by copmarison. Dodges front ends are JUNK. As for the chevs... New frame and suspension is yet to be proven dispite advertising claims.
Towing? Ford all the way. Proven frame. Great new tranny. And the new sway control makes this an easy choice.
So all in all. I would lean towards the ford regardless of the new powertrain.
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
The Following User Says Thank You to forcefed6.4ford For this addition to TDG:
post #6 of 26 (permalink) Old 05-23-2010, 07:16 PM
Thanks chris for the info.
2006 yamaha Vmax
1993 F-250 460
Near GP alberta.
CC#58
post #7 of 26 (permalink) Old 05-28-2010, 03:58 AM Thread Starter
TDG MAFIA #101
tm0231009's Avatar
Guys this is great...this is just the stuff I was looking for.
post #8 of 26 (permalink) Old 05-28-2010, 04:23 AM
ADMIN/MAFIA
neeltburn's Avatar
I still love my 6.7 Cummins. Stock there are some issues (all but one of mine where emissions related) but its a Great pulling truck. Exhaust break is sweet. Then if you tune them and delete them, well whole new experience
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #9 of 26 (permalink) Old 05-30-2010, 01:24 PM
buffalobob's Avatar
i had considered a ford but a new unproven engine and transmission both in the same truck was a little unnerving to me.
post #10 of 26 (permalink) Old 05-31-2010, 02:25 PM
Skyd Ram's Avatar
I am going to throw in a vote for the Dodge. Not because I drive one but I used to work for a huge electrical contractor and we had a mix of Ford and Dodge 1 tons as well as alot of E-350's. Our motor pool mechanics complained about the Dodge front ends but would prefer to replace ball joints and unit bearings over work under the hood of the Fords. The Ford trucks are not immune to front end problems either as they also use unit bearing design and somewhat weak ball joints. The frame on the Dodge is without a doubt the strongest on the market and the new 68rfe trans is quite a bit stronger than the 48re.
I do believe that the Ford trans is a better than the Dodge and the 6.4's and 6.7's will definitely make a lot of power in stock form. The main problem that I would have with the new Ford is the unproven motor and how much harder they would be to service. If you pop the hood on the 2011 trucks you have to look pretty hard to actually find the motor underneath all of the accessory and emissions equiptment.
2010 CCSB Laramie Ram 2500 4x4
Powered By:
H&S/Shibby/Black Ops/Flo Pro
Suspended by:
Carli Suspension/Bilstein
2008 RCLB F250 XLT 6.4 Auto
Powered By:
H&S/Flo Pro/aFE
Suspended by:
Pure Performance/Carli/Bilstein
Skyd Ram is offline
Need Opinions and Info on new trucks. tm0231009 2011+ 6.7L Power Stroke Diesel 0 05-22-2010 03:50 PM
can anyone give more info on this truck.. Bcarriveau The Parking Lot 11 11-21-2009 07:46 PM
I will give 1 million points to the person who can give me an answer blackcloudCTD95 The Parking Lot 50 01-25-2008 10:17 PM
i give the info for ajust valve mack truck e-tech! [email protected] Medium and Heavy Duty 1 08-25-2007 08:58 PM
