J35 Done and almost new turbo - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 4rcFed, this thread has received 4 replies and been viewed 1426 times.
post #1 of 5 (permalink) Old 06-05-2010, 02:13 AM Thread Starter
Super Moderator
4rcFed's Avatar
Images: 12
Well, I have had my J35 notice for awhile now, but haven't taken it in.
About a day or so ago, the truck threw a CEL, so I figured I'd get it looked at, and possible the J35 while I was there. I made an appointment for today. On the way there, the CEL went out.
I asked the dealer to check for and soft codes that might still be present. The did find a P0106 and the P2262. Well this is basically the 3rd time for the P2262. The service advisor cleared the codes and proceeded with the J35 update.
He then came and told me to schedule the "turbo cleaning." I explained that I did not feel that pulling the turbo, adding the clean out plug and having to go trough the de-soot process should be acceptable for the customer, as it really puts off the inevitable. If there is a newer turbo design that helps aid with soot buildup, let's just go there. But I understand why they can't - Chrysler procedure. So he just said talk to the Service Manager.
Talking to the Manager, he agreed with me. He then said as long as the Advisor didn't clear the code, that he could run a diagnostic test, that typically ends with a 'fail' result, therefore allowing him to just replace the turbo. Well we found out that while we were talking, the Advisor cleared the codes.
Oh well, he just said that wait for it to come up again, and then just bring it right on in. Just hope that the J35 update doesn't mask any CEL's to this issue!
2008 Dodge 2500 Mega Ram, SLT, Powered by a little 'ol 408 cubic inch six cylinder!!!
Chrysler's warranty = Not worth the paper it is printed on!!!
Gone, but not forgotten!!!
1997 FORD F-250 HD
7.3L, XLT, Off-Road Package
3.55's, E4OD, 4wd, Dana 60 swap, 3" Sky RSK, 315/70/17's on Racelines.
4rcFed is offline
post #2 of 5 (permalink) Old 06-05-2010, 02:26 AM
ADMIN/MAFIA
neeltburn's Avatar
So are you putting off the deletes now?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 5 (permalink) Old 06-05-2010, 02:29 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
i wonder if they can do the J35 recall wit everything deleted? As i would assume it would just mean retune the truck afterwards from what i hear wanna avoid having to put everything back on for a darn recall that means nothing to me at the moment but could one day if everything has to go back on.
Military Quote Of The Year
SOOTBANDIT is offline
post #4 of 5 (permalink) Old 06-05-2010, 02:53 AM
ADMIN/MAFIA
neeltburn's Avatar
I have it well sorta...they just don't know that....
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 5 (permalink) Old 06-06-2010, 10:45 AM
They can do it all it takes is updating the ecm all you need to do is pull off the programmer dont let them start the truck or the dash will light up like a christmas tree. once they are done with the ecm just reinstall the programmer.
09 QCLB 2500 Laramie G-56 Not Stock Powered by H&S
Danton88 is offline
Isspro Turbo monitor or Turbo timer proud1 1994-2003 7.3L Power Stroke 4 03-11-2010 11:46 PM
7.3 turbo wanted for 1991 pre turbo rwbmaine Whats Been Sold 0 05-24-2009 10:45 PM
1991 Ford 7.3 Non Turbo I Need To Figure Out How To Turbo It blacksmokeobs 7.3L and 6.9 IDI (Pre 1994) 7 04-01-2009 12:51 AM
Wanted: Early 99 PSD Turbo Pedistal with or without turbo. WyoDieselCowboy Whats Been Sold 3 04-22-2007 09:20 PM
Very oily tube post turbo. Means Bad turbo seals? I10HaulR 2003-2007 6.0L Power Stroke 1 03-07-2007 10:59 PM
