C15 MXS Conversion Issue - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ilovedetroits, this thread has received 0 replies and been viewed 109 times.
post #1 of 1 (permalink) Old 10-14-2018, 05:22 AM Thread Starter
ilovedetroits's Avatar
Hey guys I'm new here just looking for some help here, i have a 06 peterbilt 379 that has a mxs c15 and i just did a single turbo conversion, i used a borg warner 177148 turbo and a 6nz manifold, i got everything together and it starts and runs Good, has about 80 psi of fuel pressure, the issue I'm having is it only wants to make 20 psi of boost, i had the iva delete done and i backed all of those off and plugged the oil galley that feeds them, also unhooked the iva oil pressure sending unit, i have no check engine lights at all, anyhow it is turned up to about 580-600 now and i know 20 psi boost is to little for that and i have plugged the wastegate, checked cac and boots for leaks, it fuels hard till it hits 20 psi and then just stops fueling, BUT I was driving it around and shifted into the next gear and all of a sudden it had full fuel and made about 38-40 psi in boost but then i shifted again and back to 20 psi it went and i can't get it to full fuel any more than that one time, side note i took the resistors out of the boost wire that i had in there before any help is appreciated, some people have told me to try boost sensors it just threw me in a loop when it did full fuel that one time and made 40 psi any help is so so appreciated
series 60 750 hp
c15 de acert 650hp
blowing smoke and making her choke since 1998
ilovedetroits is offline
2008 c15 injector issue cdwood388 Medium and Heavy Duty 3 11-13-2014 02:45 AM
Headgasket issue C15 6NZ kenw007 Medium and Heavy Duty 3 02-05-2013 05:44 AM
acert mxs ecm swap 06flhtpi Medium and Heavy Duty 6 05-05-2010 11:36 AM
mxs acert josh G Medium and Heavy Duty 0 01-28-2010 03:43 AM
solenoid above oil cooler on a mxs cat bigswede Medium and Heavy Duty 4 06-16-2009 11:17 PM
