Doing a blend/colormatch with DBC - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by acesneights1, this thread has received 6 replies and been viewed 2498 times.
post #1 of 7 (permalink) Old 10-30-2010, 10:24 PM Thread Starter
acesneights1's Avatar
I have to do spot repair on my burb. I have DBC base and I forget the name of the clear but my questions are:
The area not getting color gets sanded with what grit(I used 1200)
When I finish blowing in the color can the clear be applied right over it or does it need to be saneded again ?
1986 CUCV....M1008 6.2 NV4500 5 spd
Raptor 100 LP. Serp belt conversion. 5 inch redneck master exhaust. DB2831 IP. Dmax fan. Humvee waterpump.
1981 AM General M35A2c
Lee's Auto Ranch In Ellington CT SUCKS !!
acesneights1 is offline
post #2 of 7 (permalink) Old 10-31-2010, 02:13 PM
mattsn's Avatar
1200 should be good. maybe a little bit too fine but should work.
just let the base/color coat flash off till its uniformly dull looking ( usually takes no more than ten mins ) then apply your clear allowing to also flash between coats. only reason to sand the base is to remove dirt or other inperfections. but you would have to apply more base coat after you sanded it.
mattsn is offline
The Following User Says Thank You to mattsn For this addition to TDG:
acesneights1 (10-31-2010)
post #3 of 7 (permalink) Old 10-31-2010, 03:23 PM Thread Starter
Thanks.
post #4 of 7 (permalink) Old 11-06-2010, 04:56 PM
You can use a gray Scotch-Brite pad to prep the non-color areas. Easier than using paper.
cartmanea is offline
post #5 of 7 (permalink) Old 11-06-2010, 11:13 PM
mattsn's Avatar
yes but the scotch pad would be a much more inconsistent scratch. very un uniformed. the sand paper is the best tool. As a painter i never use scotch pads.
mattsn is offline
cartmanea (11-06-2010)
post #6 of 7 (permalink) Old 11-12-2010, 08:18 PM
HalfAst Racing
skippy's Avatar
Images: 1
thats interesting.i use scotch brite pads on everything i paint.thats gotta suck prepping bumpers with sand paper.use gray under clear,red under base and sealer.you can use all the way down to 500gr under clear.
2004 f250 cc/sb,magnaflow turbo back.rockin rcd tunes 18" harley wheels
2001 excursion 6in 35s
1993 mustang lx,6.0l 5r,project rattlesnake
skippy is offline
post #7 of 7 (permalink) Old 11-13-2010, 03:21 PM
mattsn's Avatar
not saying it cant be done , just saying that the sand paper will provide a much more consistent and uniformed scratch. also it cuts, scotch pads actually tare the surface. another quality that the sand paper provides it it levels the surface , cutting the natural texture of the paint /orange peel to a level surface.
and no it doesnt suck using sand paper on bumpers. Also 3M makes an alternative to scotch pads. they are a foam pad with a sand paper like texture on them. the advantage of them over the normal scotch pad is that the cutting surface is uniformed and cuts like sand paper. it is foam so it is absolutely as flexible as the scotch pad. Also, they come in several textures.
mattsn is offline
Rotella T5 Synthetic Blend? NCfarmboy 2003-2007 6.0L Power Stroke 51 06-25-2010 09:51 PM
blend door actuator nextlevel 6.5L Diesel Engine 2 05-06-2008 12:47 AM
Winter blend fuel wastedwagesracing The Parking Lot 2 02-10-2008 10:57 PM
WVO blend??? diesel spaz 5.9L Cummins (1998.5-2002) 37 07-15-2007 03:42 PM
Hmmm, new blend in the NV5600...I like it! steved 5.9L Cummins (2003-2007.5) 3 06-29-2007 09:32 PM
