gravity feed guns - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RacerX, this thread has received 6 replies and been viewed 842 times.
post #1 of 7 (permalink) Old 04-13-2006, 06:15 PM Thread Starter
gravity feed guns
After reading the poll on guns i was wondering which gravity feed guns will spray upside down?
RacerX is offline
post #2 of 7 (permalink) Old 04-13-2006, 07:36 PM
Got Diesel ?
Thats a tricky question. The answer is none of them(stock) and all of them(when equipped with a 3M PPS) . The 3M PPS cup system allows the spray gun to operate with no air present in the cup therefor upside down operation is possible... click here it's a PDF file http://multimedia.mmm.com/mws/mediaw...66Sx2wCOrrrrQ-
2005 F250 6.0 Auto, 4x4, Lariat, Crew, ESOF, bedliner, Sirius radio w/PIE, custom emblems, Tow command, Pwr rear slider, L/S rear, Camper pkg, Two tone Toreador red/tan, Built 8/04
Old truck (buyback) 2002 F250 7.3, Auto, 4x4, Lariat, Crew
My 1970 Cadillac DeVille
South_paw is offline
post #3 of 7 (permalink) Old 04-13-2006, 07:56 PM
i love the 3m setup, I use it a lot... it is less messy which makes cleanup a snap and sprays at any angle
the only down side i can think of about that setup is that the cups are kinda small
JLayne is offline
post #4 of 7 (permalink) Old 04-13-2006, 11:19 PM
and spendy...
partsguy662 is offline
post #5 of 7 (permalink) Old 04-14-2006, 01:31 AM
Will the new Sata disposable cups allow you to do the same thing (spray upside down)? I have some jobbers selling them but I haven't quizzed them on how they work vs 3 times as much money's cups.
TooMuchBoost is offline
post #6 of 7 (permalink) Old 04-14-2006, 01:49 AM
Got Diesel ?
The SATA cups allow you the same and a little more. You can tilt the cup due to the flexible neck design. The downside(it's a biggie) is the SATA cup has a vent with a cap on it. If you forget to cap the vent it will leak fast and hard. Advantage 3M
post #7 of 7 (permalink) Old 04-14-2006, 03:00 AM
I need to do some homework on this. The biggest gripe about the 3M's was heavy metallics and pearls spraying uneven and supposedly the bagless Sata's corrected this.
I had a handful of jobbers that Tony from Sata put on an early bird schooling if you will but I never followed up on how the Sata cups worked. Personally, I have no use for either but if one works better than the other I need to know in case a painter asks me.
In general the 3M cups never really took off in metro Atlanta but it could be totally different elsewhere based on how hard the reps pushed it.
I guess it's like UV primer. Supposedly that stuff is taking off in certain areas but it has all but flopped around ATL.
