If you have a lot of wet sanding and buffing to do wet sand the ride then pull it out in the sun for at least a couple of hours (remember UV light and heat flow solvents). When you are ready to buff pull the ride in and let the metal cool to room temperature before you begin buffing. This will literally change/flow a 1200 grit scratch to a 1400 or 1500 grit scratch which obviously means less buffing.
If you only have a 1/4 panel to do with say a nasty color like black you can put a heat lamp on the panel for 15-20 minutes @ 24". Once again let it cool then buff it.
If you have to sand it anyway you have nothing to lose other than the time it sat outside and remember UV is present even when its cloudy which is why you can get sunburned at a cloudy beach.
An 'old' black finish is a mofo to buff swirl free and I would not recommend wet sanding your factory finish because the milage isn't there. One might be able to knock the orange peel off with some 1500 grit wet sanding and buff it slick but they better know what they are doing.
Related Threads
The Diesel Garage
1.2M posts
57.3K members
Since 2005
