Wet Sanding - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hhrecovery, this thread has received 5 replies and been viewed 738 times.
post #1 of 6 (permalink) Old 04-18-2006, 06:42 PM Thread Starter
MAFIA #8
hhrecovery's Avatar
Images: 1
Wet Sanding
Why is it done??? I have read up on how to do it but I am just wondering WHY. Why is it better than dry sanding??? Thanks.
2003 F250 "Pulling Truck"
hhrecovery is offline
post #2 of 6 (permalink) Old 04-18-2006, 06:57 PM
It keeps the ultra fine grits in the wetsanding paper from clogging. Also a nicer process to allow your paper to float over the surface you are trying to get as flat and smooth as possible..........
RacinDuallie is offline
post #3 of 6 (permalink) Old 04-18-2006, 10:01 PM
Like he said but its a mess.
Many shops have gone to a 'dry' DA paper for 600-1500 grits now but the problem with the finer grits is you must keep the paper clean all the time not grind a piece of trash into the surfac which leaves little J's in the finish. Many clean the paper by buzzing the DA against their work short or pants.
Indasa's dry fine grit DA sanding paper works very well with water as lubricant.
I personally like wet sanding though its only a hobby to me and the last thing any painter wants is to blow a drop or 20 of water onto his paint job from the air pressure of the gun blowing it out of a molding or jamb. DIY's have the time to water sand the night before painting and leaving all hinged surfaces open over night to dry out.
Here's a trick: Add just a few drops of car wash concentrate to a gallon of wet sanding water for a lubricant.
TooMuchBoost is offline
post #4 of 6 (permalink) Old 04-19-2006, 03:04 AM
and wrap your sandpaper around a sponge or rag :Thumbup:
excellent tip
JLayne is offline
post #5 of 6 (permalink) Old 04-19-2006, 10:35 AM
UpstateDieselGuy's Avatar
I've yet to attempt wet sanding. I will get brave some day. Chris
SOLD
UpstateDieselGuy is offline
post #6 of 6 (permalink) Old 04-19-2006, 11:14 AM
I never thought of this but will try it on the Dodge tomorrow.
Excellent tip yourself!
