Engine Bay - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by wolfeyes89, this thread has received 10 replies and been viewed 1601 times.
post #1 of 11 (permalink) Old 12-31-2008, 02:19 AM Thread Starter
Engine Bay
I plan to detail my truck on Friday. The problem I'm having though is that idk how to clean the engine bay. I have Megs degreaser but I've heard that if you throw cold water at your engine the block will crack due to the temp change. Is this true? How can I avoid this?
I've heard that the best method is to keep the engine on while your spray it. Wouldn't that be more dangerous though as the temp change will be greater?
wolfeyes89 is offline
post #2 of 11 (permalink) Old 12-31-2008, 02:23 AM
I would have it steamed cleaned while it is running. Best way to do it, is have it done by a detail shop so they are liable for what ever goes wrong.
2008 F-250
Stock. Hoping one day to get the spartan.
Out of work?
Hungry?
Why dont you eat your rice burner!!!!
gporter302 is offline
post #3 of 11 (permalink) Old 12-31-2008, 02:25 AM
I Eat Rice
forcefed6.4ford's Avatar
Never heard of cracking a block. Have heard about getting water in harnesses.
Use a good quality degreaser and only a low pressure hose. I fu r still concerned about the tepm change on a warm engine. Wash the outside of the truck first to allow it the engine to cool down until you can get started on it.
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
post #4 of 11 (permalink) Old 12-31-2008, 02:25 AM
Rene G's Avatar
I always wash my enine bay, I just use a pressure washer whenever I lean te rest of the truck
09 F-350 FX4 lux package, everything but sunroof
Suncoast rebuilt trans. and converter
Line-X box liner and rocker panels
4-lightforce lights on KC light bar
OUO Traction 5"traction blocks
Icon adjustable track bar
Air bags and compressor
Icon 2.5" Leveling kit
Marathon sled deck
Flo-pro exhaust
S&B intake
Waiting for time to install
Dirty Diesel cold side I/C pipe
CANADIAN CLUB MEMBER #15
SINGLES CLUB MEMBER #227
spartan tuned courtesy of www.dirtydieselcustoms.com
Rene G is offline
post #5 of 11 (permalink) Old 12-31-2008, 02:28 AM
sledneck57's Avatar
what your hearing of is cracked heads. and yes it happens but only on aluminum headed vehicles(gassers). diesels are cast block and cast head.
08 F-350 CC SB 4X4
Zex Nitrous
Spartan Phalanx
AFE stg 2
Flo-Pro 5"
Lift\Rims\Tires
Canadian Club #0
Ridin Dirty Club #37
sledneck57 is offline
post #6 of 11 (permalink) Old 12-31-2008, 02:59 AM
GUTTS's Avatar
must have bin a chevy guy that told him that lol
GUTTS is offline
post #7 of 11 (permalink) Old 01-02-2009, 05:04 PM
Now Cummins Powered
MRBOHN23's Avatar
I wash my engine once in a while. I own a detail business on the side and never have any problems cleaning my engine. Just spray it down with a good degreaser. I like super clean and its biodegradable. Try not to soak any electronic harnesses and you should be fine.
2004.5 Dodge 2500 Quad Cab Cummins Powered, Laramie, Tow Pkg., Snow Plow Pkg., 4.10 Rears.
2008 Ford F-250 Crew Cab Lariat, 6.4 Powerstroke, Snowplow Prep, Automatic 3.73 posi, 18 inch wheels, SOLD!!!!
MRBOHN23 is offline
post #8 of 11 (permalink) Old 01-03-2009, 04:36 AM Thread Starter
Thnx for all the replies they really helped.
Ya sledneck lol it was actually on the Chevy forum and they did say heads. The reason i added block to it though, is because the manual says that the block will crack. I just noticed though that it is in the 5.4 and v-10 section. There is no info on washing for the 6.4. I went ahead and cleaned up the engine yesterday, I sprayed the hood with a p washer and some of the harder spots. For peace of mind though about 45% of it was done by hand and washes. I'll post some after picks after I apply the dressing tomorrow.
MRBOHN23:Super Clean looks good but I already got this Megs one:
You should try it, i think you'd like it it works like a charm.
post #9 of 11 (permalink) Old 01-03-2009, 05:31 AM
pyro2nite's Avatar
You can try Purple cleaner at Home Depot made by Zepp. Just spray it on then wash off. About $6.75 a gallon. Will not leave a resdue.
2008 FX4 3:73 ZF-6 SC SB Transfer Flow
Singles club member 166 H&S Mini, KEM Tunes, S&B intake
pyro2nite is offline
post #10 of 11 (permalink) Old 01-03-2009, 01:43 PM
GUTTS's Avatar
Not knocking the Chevy guys but i only said that because they are aluminum so i figured they would say that.
GUTTS is offline
