Cleaning glass - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bullrack, this thread has received 17 replies and been viewed 1612 times.
post #1 of 18 (permalink) Old 10-04-2006, 07:01 PM Thread Starter
Udderly Delicious
Cleaning glass
What is used to remove water spots from mirror glass and side windows? I've tried the vinegar and newspaper but didn't work real well. I baked the water spots onto my mirrors before installing the mirror heat switch that Ford deemed unneccesary. Anyone know any foolproof methods?
"To hell with a 6.0, make mine 6 in a row"
'03 "TNT Ranch Edition" F350 CrewCab Lariat 4x4 DRW 12V Cummins, P&P head with 60# valvesprings & O-Ringed, ARP 625 studs, Colt cam, 4K GSK, HX40S/HT3b Twins, ZF6spd. with Valair Ceramic/Kevlar, manual hubs, 3.73's, 5.5" lift/w 285 Dayton Timberlines and 2" Wheel Spacers.
Bullrack is offline
post #2 of 18 (permalink) Old 10-12-2006, 01:31 AM
when all else fails I use glass polish. My water leaves bad water spots too and they are a pain to get off glass and wheels, I usually try to keep a thin coat of carnuba on my mirrors it helps repell it and make them dry cleaner.
6OWED is offline
post #3 of 18 (permalink) Old 10-12-2006, 02:01 PM
Water spots are no fun...especcially when they have become heat baked to your paint or windows... i believe i have tried just about everything to get rid of'em...but nothing seems to work other than replacing the window or wetsanding the paint. the best cure for this would be prevention.
LIKES2PlayDrty is offline
post #4 of 18 (permalink) Old 01-16-2007, 04:14 PM Thread Starter
Udderly Delicious
OK, I seem to have polished my glass back to it's original luster. What about the paint. This truck has some major water spots due to lift being too big for my garage. I've since got my RV shed built for protection. This truck is '03 Arizona Beige. What can I do to remove these? The best way? Right way? Easiest way?
Bullrack is offline
post #5 of 18 (permalink) Old 01-16-2007, 04:17 PM
is here and there.
Rcannon's Avatar
Images: 11
can you elaborate more on what and how you did this?
Rcannon is offline
post #6 of 18 (permalink) Old 01-16-2007, 04:57 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
you wire it up to one of your upfitter switches... you can get the wire on the back side of the fuse box is the easiest... ill let you know when I find which one it is again.
2003 F250 "Pulling Truck"
hhrecovery is offline
post #7 of 18 (permalink) Old 01-16-2007, 05:01 PM
is here and there.
Rcannon's Avatar
Images: 11
Guess I should install some upfitter switches.
Rcannon is offline
post #8 of 18 (permalink) Old 01-16-2007, 05:52 PM
i to am wondering the best way to getread of the watter spots on the paint, i have a brand new 06 and it has them :{
alldiesels is offline
post #9 of 18 (permalink) Old 01-16-2007, 06:26 PM
plainredtruck's Avatar
Images: 11
plainredtruck is offline
post #10 of 18 (permalink) Old 01-18-2007, 03:12 AM
fordt
www.adamspolishes.com This stuff is awesome! TDG members get a discount also! Just type in TDG for the discount code.
