Rust stain - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RacerX, this thread has received 3 replies and been viewed 960 times.
post #1 of 4 (permalink) Old 10-05-2006, 05:24 AM Thread Starter
Rust stain
Anyone have a rust stain remover they can recommend? I have a stain on Chrome that must be removed without hurting the chrome finish.
RacerX is offline
post #2 of 4 (permalink) Old 10-06-2006, 01:58 PM
TDG Mafia Member # 37
01blkf250's Avatar
Hey Bill, I have always had good luck with Never Dull, from Eagle One. Seems to work really well, but my wife just bought some cleaner and polisher at the Street Rod Nationals a couple weekends ago and that stuff is absolutely amazing. I will find out the name of it and will Pm you later today after I get home from work. Will also see if there is a website associated with this product.Should be sending something your way next weekend hopefully.Gene
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
post #3 of 4 (permalink) Old 05-28-2007, 04:37 PM
bmoeller's Avatar
http://www.permatex.com/products/aut...solver_Gel.htm
Can be used on chrome, but says to not leave on the surface longer than 5 minutes.
I have used some a bit, and so far, I like what it can do. I bought the little spray bottle.
"Obama = Hoax and Chains"
bmoeller is offline
post #4 of 4 (permalink) Old 05-28-2007, 10:10 PM
RacerX,
Check out our Metal Polish #1. It safely and effectively removes light rust and oxidation. It chemically cuts the metal to remove these impurities.
Thanks and let us know how you make out!
