I started this in the wrong forum - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by POWER STROKE 99, this thread has received 3 replies and been viewed 626 times.
post #1 of 4 (permalink) Old 12-23-2006, 03:22 AM Thread Starter
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
Which do you prefer, undercoating or paint for underbody and chassis.
POWER STROKE 99 is offline
post #2 of 4 (permalink) Old 12-23-2006, 03:43 AM
Im guessing it would depend on your climate, what do you drive in? How much protection do you need? I have lived in arid climates where a '68 beetle can have original paint and virtually no rust. And if your into racing, rust weighs less than any paint!
:2cents
mckey73 is offline
post #3 of 4 (permalink) Old 12-23-2006, 03:55 AM Thread Starter
I live in WV and I am mostly worried about the salt in the winter from the roads, and something easy to clean and looks good.
post #4 of 4 (permalink) Old 01-26-2007, 10:41 PM
Sems Makes A Great Rustshield Chassis Enamel With A Hardener. It Doesn't Hold Dirt And Moisture Like Rubberized Undercoating. For Rust Protection In Vt. We Spray The Whole Underside Of Truck With Bar And Chain Oil And Drive Down A Dusty Road{it Turns To Tar] In The Fall.you Can Pressure Wash It Off In The Spring.
hacksaw is offline
