HELP grease spot - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by alldiesels, this thread has received 10 replies and been viewed 1249 times.
post #1 of 11 (permalink) Old 01-22-2007, 07:49 PM Thread Starter
HELP grease spot
well got a grees spot on the back of my front seat (the carpet part) and my detail guy told me to use just a lil bit of paint thiner and a rag???
what do you guys use, this is a new truck and try to keep em cleen so i gata get this out.
robert
alldiesels is offline
post #2 of 11 (permalink) Old 01-22-2007, 08:12 PM
Try WD-40. It'll take the grease off, and then soap & water to get the '40 off. Should do it and not cause any other problems.
2003 CHEVY LT 2500HD Duramax LB7 ExtCab/SB 4X4
Hypertech PP3, Truxedo Box Cover, Hijacker 5W Hitch
haunruh is offline
post #3 of 11 (permalink) Old 01-22-2007, 08:27 PM Thread Starter
wd40 on the carpet?
post #4 of 11 (permalink) Old 01-22-2007, 09:36 PM
Supporting Vendor
SeeYa's Avatar
Images: 1
try some simple green
SeeYa is offline
post #5 of 11 (permalink) Old 01-22-2007, 10:17 PM Thread Starter
simple green won't discolor the carpet?
post #6 of 11 (permalink) Old 01-22-2007, 10:45 PM Thread Starter
should i dilute it or use full strength?
robert
post #7 of 11 (permalink) Old 01-22-2007, 10:46 PM
Supporting Vendor
SeeYa's Avatar
Images: 1
Umm....I would dilute first, then strengthen a little if needed.
SeeYa is offline
post #8 of 11 (permalink) Old 01-23-2007, 01:52 AM
4cstr
We've had really good luck with the Oxy-clean carpet cleaner. I accidently got some Tar on the house carpet...and this stuff took it right up.
post #9 of 11 (permalink) Old 01-23-2007, 05:54 PM
TDG Member Since 2004?
KarTek's Avatar
In my experience, the carpet is pretty tough if you're talking about the fuzzy stuff in the floor and on the backs of the seats. I accidentally spilled about a cup full of Meguiar's rim cleaner (the heavy duty stuff that is only supposed to be on the rims for 30 sec.) on my carpet. The only way I knew was that I started to smell it. Anyway, it was on there for at least an hour before I could get it off and the carpet was none the worse for wear.
If it's regular petro based grease, I'd say some dishwashing detergent or laundry treatment would remove it.
-Evan
2000 Ford F250, Merillion, 6sp, AIC, DPTuner, BB turbo, Adreneline pump, modified IDM.
1998 Mercedes E300, Custom injector nozzles, soon to have Eaton M90 supercharger, 7.5mm pump elements, Holset HX40 turbo and a full custom intake and exhaust system = 400HP from 3.0l
KarTek is offline
post #10 of 11 (permalink) Old 04-22-2007, 12:40 AM
OBS
I have been a carpet guy for five years, and in if theirs a stain we clean it with lacquor thinner. its water based and it doesn't hurt the carpet at all. don't know about auto carpet, but don't use paint thinner, its oil based and you will see greasy spot where you put it.
97 F-250 7.3 psd 4x4: homemade Intake, fpr mod, IDM mod, 18k mod, HX mod, a pillar w/ 3 autometer gauges, 3" downpipe, minus muffler and cat.
stroker_baldy is offline
