Sand in carpet - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by POWER STROKE 99, this thread has received 8 replies and been viewed 914 times.
post #1 of 9 (permalink) Old 02-12-2007, 04:47 AM Thread Starter
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
Sand in carpet
How do you get sand out of the carpet? I can sweep in the same place four ten minutes and it keeps coming up.:shrug:
POWER STROKE 99 is offline
post #2 of 9 (permalink) Old 02-12-2007, 10:49 AM
UpstateDieselGuy's Avatar
Your best bet is to Shampoo the carpet. This will extract the sand/dirt better than just vacuuming. You can either use a shampoo machine or spray cleaner on the carpet, lightly mist it with water (enough to make it lather up), and extract it with a Wet/Dry Vac. After any kind of shampooing you want to let it air out and dry good though. Hope this helps. Chris
SOLD
UpstateDieselGuy is offline
post #3 of 9 (permalink) Old 02-12-2007, 10:53 AM Thread Starter
I will try that.:thanks:
post #4 of 9 (permalink) Old 02-13-2007, 01:57 AM
I hope it works for ya. Chris
SOLD
post #5 of 9 (permalink) Old 03-17-2007, 05:24 AM
The most effective way I have found is an old carpet beater.Hang the carpet on a fence with the pretty side out and slap the sand out, the carpet is pushed back from the sand and the sand falls.
Second way is with a vacuum that pulls a high volume and low prssure, slide slats under the carpet so air can go through the carpet but a lot of carpets have glue that won't let air through. If there is no air flow on the bottom it doesn't help. Back to beating with a carpet beater or much patience with a vacuum.
keydl
keydl is offline
post #6 of 9 (permalink) Old 03-17-2007, 01:08 PM Thread Starter
I may just replace the carpet, the sand drives me nuts!!!!!!!!!!!!
post #7 of 9 (permalink) Old 03-17-2007, 01:33 PM
fordt
I lived in Florida for about 6 years. The road I lived on was sand, and all the interior ranch roads were sand. I had enough sand in the floor of my truck to build a sand castle! I never could get it all out. I just learned to live with it
post #8 of 9 (permalink) Old 03-17-2007, 05:40 PM Thread Starter
My truck came from florida.
post #9 of 9 (permalink) Old 03-17-2007, 11:24 PM
plainredtruck's Avatar
Images: 11
Repeat after me, "Husky Liners".
Cover it and forget it.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
