DuPont Roll-In Bedliner???? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bigdraft, this thread has received 11 replies and been viewed 3733 times.
post #1 of 12 (permalink) Old 03-15-2007, 06:55 PM Thread Starter
The Big Meanie
bigdraft's Avatar
Allright guys........the body shop guy put a DuPont Roll-In Bedliner kit in my Dodge for me. How well does this fair with Rhinolining and all the other ones? Is the DuPont one any good? Anything I should look for?????
Kevin
Boys Stroke It...Men RAM It
Dually Club Member
Farm Club Member
I Got A Named Bubba
In Progress...
FOREVER FARMS
What Is A Farm With No Barns?
bigdraft is offline
post #2 of 12 (permalink) Old 03-18-2007, 06:03 PM
fordt
I have never heard of any problems with the roll in bedliner, but I can't imagine it would be as thick as a spray in......I have absolutley no information to back this claim up
post #3 of 12 (permalink) Old 03-18-2007, 08:38 PM
Bouncer
Everyone I have talked to that has put in the roll on liner has been terribly disappointed in about 6 months. It starts peeling off and will scuff up very easy. The reason Line-X and Rhino Liner are so durable is because they are sprayed on hot. More so the Line-X than the Rhino, but both go on at greater than room temperature and they adhere much better to whatever they come in contact with. The heat is the key to a good secure bond, not to mention that they have a good product as well. Your mileage may vary, but I have not saw a roll on liner last very long yet.
post #4 of 12 (permalink) Old 03-18-2007, 09:04 PM
TDG Mafia Member #21
I don't know about the DuPont liner but Herculiner sucks. I am sure they are similar. The Herculiner was destroyed within a couple months of direct sun and it is easy to chip up when putting stuff in the bed.
2007 F350 CC 4x4, EGR delete, stock for now
Old truck :"01" Dodge 3500 DRW. Goerend Bros w/ triple disk, Edge Drag Comp, Jammer Stage 5's, Turnbuckle, Dakota Digital and ISSPRO Gauges, BHAF,4" FLO-PRO exhaust, Vulcan kit, Holley Blue Pump, TC Lockup Switch, Snow stage 2, a few more little bits in the works
377hp and 823tq @ Smokin' (with stage 3's/no drag upgrade)
"400" club wannabe
akapparos is offline
post #5 of 12 (permalink) Old 04-08-2007, 01:58 AM
I agree, I did the home version of herc liner roll on and then had one of the trucks sprayed w/"commercial" herc liner supposed to be hot sprayed like rhino and linex both sucked (herc liner). id go linex persoanlly and their warrenty good anywhere in america.
#23 Singles Club
thejdman04 is offline
post #6 of 12 (permalink) Old 04-08-2007, 02:16 AM
plainredtruck's Avatar
Images: 11
We've applied Herculiner to several of the shop trucks in the last 6 months. The only problem I've noticed is on the tailgates of one with a service body, the rolled bar across the top is shiny metal again. That's because everything goes across the top of that tailgate.
The techs aren't kind to the trucks and are even worse on the bedliners.
I plan to try Southern Polyurethanes' bedliner kit next at the shop.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #7 of 12 (permalink) Old 04-08-2007, 04:40 AM Thread Starter
The Big Meanie
bigdraft's Avatar
OK....this roll in bedliner SUCKS!!!!! I allready have 3 spots where it has chipped off and is down to the paint. Next question.....can I have a Rhino liner or similar sprayed in on top of the roll in liner, or do I have to figure out how to remove the roll in crap????????
Kevin
Dually Club Member
Farm Club Member
I Got A Named Bubba
In Progress...
FOREVER FARMS
bigdraft is offline
post #8 of 12 (permalink) Old 04-08-2007, 04:45 AM
Bouncer
If you get Line-X they sand and scuff everything anyways. I am sure they would charge extra to sand that stuff off theough.
post #9 of 12 (permalink) Old 04-08-2007, 02:48 PM
UpstateDieselGuy's Avatar
They will have to have all of that garbage removed as it needs to bond to the metal/paint. If they sprayed it over that garbage that is not adhearing it would come off as well. Chris
SOLD
UpstateDieselGuy is offline
post #10 of 12 (permalink) Old 05-20-2007, 03:17 AM
Thanks guys I've been wondering about those roll on liners.
Wrenchbender is offline
