hood scoop - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 6L strokin, this thread has received 3 replies and been viewed 810 times.
post #1 of 4 (permalink) Old 04-11-2007, 10:17 PM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
hood scoop
well, i have a $100 gift cert. that my g/f got me for jc whitney...problem is, they dont have ANYthing i want! i was thinkin maybe buyin a hood scoop, takin it to a body shop, getting to cut a hole in my hood, put on the scoop with bondo, etc. making it look like a one peice hood and having a "custom" ram air hood. seems like a pretty good and fairly cheap idea to me. however someone told me i may get water in it and on my motor and fry sensors or somethin....:shrug: whats yalls input? Thanks!
Darin
Previous Rides:
1997 F150 EC SB 4x2 xlt red
6L strokin is offline
post #2 of 4 (permalink) Old 04-11-2007, 11:13 PM
Bouncer
Just get the stick on ones if you don't want to buy a ram air hood. Body shop and cheap never go together in the same statement.
post #3 of 4 (permalink) Old 04-17-2007, 04:06 AM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
[QUOTE=Bouncer]Just get the stick on ones if you don't want to buy a ram air hood. Body shop and cheap never go together in the same statement.[/QUOTE]
not unless you know a fella...: :
Previous Rides:
post #4 of 4 (permalink) Old 04-17-2007, 06:50 AM
TDG Mafia Member #56
Dieselwrencher's Avatar
I say do it. I had a 97 psd with a cervini's mach 1 hood on it and it had 2 open scoops and it was fine. Trust me it saw plenty of rain and snow and the truck is still running around somewhere with the same set up. So I think you will be just fine.
Putco light bar
Dieselwrencher is offline
