Under Coating - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TOMDIESEL, this thread has received 6 replies and been viewed 908 times.
post #1 of 7 (permalink) Old 08-30-2007, 12:29 AM Thread Starter
Under Coating
Tell me if I'm crazy like my wife tells me. I have a 2003 F250 4x4 crew cab and i had surface rust underneath the truck so i first pressure washed it, then the next day i sand blasting all the rust off the body and the frame then blew it all off and sprayed rust converter (the stuff that tuns rust black and seals the steel). Then i bought one of those truck bed liner spray guns and got roof coat tar (the stuff thats real thin to begin with) and thinned it out more with paint thinner so it would spray though the gun and undercoated the whole bottom end of the truck it looks great! when it drys it's not tacky. And no even in 100 degrees it dose not rain tar on the driveway! And yes I covered the exhaust so it wouldn't get tar on it!
TOMDIESEL is offline
post #2 of 7 (permalink) Old 08-30-2007, 01:07 AM
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
Sweet deal.....I never thought of doing it that way.........I just used about 30 cans of 3M under coating on the under body and painted my frame.
POWER STROKE 99 is offline
post #3 of 7 (permalink) Old 08-30-2007, 04:02 PM
I just use Fluid Film twice a year. Worked good on my old truck, as it looked like new underneath. :smoke
DieselMonk is offline
post #4 of 7 (permalink) Old 11-20-2007, 09:27 AM
Undercoating
Can you post some pics of the undercoating, would like to see how it looks and how it came out. I was wondering about having my under carriage done but there are no places that does this anymore, I use to do this at Ziebart years back, even done Rustproofing,Bedliners, Detailing/Waxing Vehicles,Sunroofs.
That was a cool Job.
2007 Silverado 2500HD LT Ext Cab /Black Ext/Ebony Int/ LMM Diesel
Nolafishr is offline
post #5 of 7 (permalink) Old 11-20-2007, 09:47 AM
TDG Mafia Member #82
Im curious to see pictures!!
SCT tuned by Dfuser
RBP 4" Turbo Back Straight pipe
Airaid Cold Air
6in Superlift
2in Blocks
39.5 Iroks on 20in. Monsters
Bruiser6.0 is offline
post #6 of 7 (permalink) Old 11-21-2007, 09:34 PM
mattsn's Avatar
question, if you sandblasted the rust off , then what did you spray the rust converter on? that stuff doesnt stick to clean shiny bare metal very well. least none that i have ever delt with do
mattsn is offline
post #7 of 7 (permalink) Old 01-02-2008, 01:57 AM
do you have any pics and also did it make the truck quiter
WHT350ON22S is offline
