thanks guys - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mattsn, this thread has received 10 replies and been viewed 1133 times.
post #1 of 11 (permalink) Old 04-15-2008, 01:18 AM Thread Starter
mattsn's Avatar
thanks guys
I spent most of this weekend cleaning my truck . from reading so many posts in this forum from you guys who use "Adams" ,i decided to give it a shot. I used the "Revive Polish" followed with the "buttery Wax " i also used the all purpose cleaner, VRT dressing and the under carriage spray. i did all the waxing and polishing by hand and there are no swirls to be found. i was glad to find it easy to remove also. So, i just wanted to send out a thanks to you guys for turning me on to this product and a thanks to Dale for recommending witch products to use. Thanks :Thumbup:
mattsn is offline
post #2 of 11 (permalink) Old 04-15-2008, 01:43 AM
Isn't it nice when things just seem to work so well! Contact us if you need any other further assistance!
post #3 of 11 (permalink) Old 04-16-2008, 10:55 AM
fordt
Glad you liked it! I won't use anything else, and poked some fun at other guys at Smokin' cleaning with the "others" :
post #4 of 11 (permalink) Old 04-16-2008, 04:36 PM Thread Starter
mattsn's Avatar
only thing i could complain about is since it rained a bit the other night the VRT dressing ran down the side of my truck. sucks cause i put it on lightly and ran over it with a dry cloth to get any extra off so that i could avoid this problem. no big deal though
mattsn is offline
post #5 of 11 (permalink) Old 04-16-2008, 07:28 PM
Ran down the side of your truck? Where else did you have it applied, bed liner I guess?
VRT is water based unlike oil based products which is why it still shines and is dry to the touch. Because it's water based, the rain would remove it.
post #6 of 11 (permalink) Old 04-16-2008, 09:37 PM Thread Starter
mattsn's Avatar
on my black plastic parts, bed rail caps, door handles , mirrors . dont get me wrong im happy with it i just wish it didnt run , sorta defeats the purpose . it looks great till it rains then its all over everything.
mattsn is offline
post #7 of 11 (permalink) Old 04-22-2008, 09:27 PM Thread Starter
mattsn's Avatar
Well now the VRT dressing that I applied to my exterior plastic ( bed rail caps, mirrors , and door handles ) has begun to have a whiteish haze . so i guess the first time of using that will be my last time. Not sure why this would happen when it says it is for exterior rubber, and plastics.
I am still happy with the polish and wax
mattsn is offline
post #8 of 11 (permalink) Old 04-22-2008, 10:25 PM
SLAPS President
teamroper60's Avatar
Images: 9
That sounds really weird........... Any possibility the bottle was mislabeled and actually contained some other product??
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #9 of 11 (permalink) Old 04-23-2008, 12:00 AM Thread Starter
mattsn's Avatar
not sure , its the first time i used it so i have no other bottle to compare it to
mattsn is offline
post #10 of 11 (permalink) Old 04-25-2008, 02:20 AM
SLAPS Treasurer
I have used the VRT several times on my tires and plastic trim. I have not noticed it running or turning white.
Chris
97 F-350 cc srw 4X4,White,Cab hi Leer,4.10's,Hypermax H2E turbo,BDP stage 1 injectors and fuel system,BTS tranny and dual HPOP,Banks intercooler,4-pos. chip programmed by Tony Wildman,Joe Servo idm,Tymar intake and hx mod,missing kitty,4" exhaust before rear wheel,Skyjacker 4" system,35" BFG's w/Weld wheels,Amsoil dual bypass filterw/Amsoil syn. oil and diff. lube.
SLAPS treasurer
ytee is offline
