clear coat not shiny enough - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bighatben, this thread has received 8 replies and been viewed 6087 times.
post #1 of 9 (permalink) Old 01-08-2009, 12:38 AM Thread Starter
ok i painted the grille on my f250 with duplicolor spray paint. i primed it, painted it, and clear coated it the right way. And it looks pretty good but it still doesnt match the gloss of the truck paint. what can i do to make it shinier. im pretty new to painting stuff so please help.
Truck Info: 04.5 D-max, 2500HD, 4x4, CC with 6" susp lift and 35's, 4" MBRP SS exhaust, 150 hp Van Aaken Flip Chip. :
Bighatben is offline
post #2 of 9 (permalink) Old 01-08-2009, 12:41 AM
08powersmoke's Avatar
what color? and what year?
2008 f250 4x4, auto, 3.73
spartan tuned..
37x13.50r20 interco ssm16
pioneer z3 navi, and a few other ear goodies...
B.O.M.B SQUAD #20
RIDING DIRTY CLUB #35
RIDIN' HIGH #23
SINGLES CLUB #199
08powersmoke is offline
post #3 of 9 (permalink) Old 01-08-2009, 01:19 AM Thread Starter
oxford white 2000
post #4 of 9 (permalink) Old 01-08-2009, 01:51 AM
Kyle`s Car Care
forrestk's Avatar
well your prob not going to get the same gloss out of a spray can as whats on your truck but if you sprayed the clear on to thick you can actually dull it out also
2006 Ford F-250 6.0L
forrestk is offline
post #5 of 9 (permalink) Old 01-08-2009, 01:53 AM
exactly, the key is very very thin and preparation. probably gonna get as close as you are gonna get if using rattle can bud
spartan tuned..
B.O.M.B SQUAD #20
RIDIN' HIGH #23
SINGLES CLUB #199
post #6 of 9 (permalink) Old 01-08-2009, 11:50 PM Thread Starter
well that kinda sucks but thanks for letting me know.
post #7 of 9 (permalink) Old 02-04-2009, 03:27 AM
TDG #97
2008TTCC's Avatar
What ya could try is wet sanding... start with 400 then 600, then 1200, then 1500 then some polishing compound, then fine polish, then some wax!
MAFIA #97
RIDIN' HIGH #28
RIDIN' DIRTY #40
SINGLES CLUB #203
B.O.M.B. SQUAD #67
2008TTCC is offline
post #8 of 9 (permalink) Old 02-13-2009, 05:28 PM
For a small part like that just grab a cheap touch up hvlp from harborfreight and go the paint supply store and get some real paint like dupont or even some of the cheaper bases like valspar should be better than duplicolor. You can get a quality clear for cheap too, just look for one thats designed to match factory panels because some clears provide to much gloss to match right. All you would need is the minimum amount that they can mix for you. My place can mix 1/2 pints minimum which is rare, but see if they can do it for you.
DHTD is offline
post #9 of 9 (permalink) Old 02-14-2009, 07:27 PM
mattsn's Avatar
wet sanding clear with anything more aggressive than 1000 grit is going to remove the clear right away. by time you start with 400 there wont be any clear left
DHTD has the best option for you . you cant get a rattle can to match the gloss of a true automotive Clear . even some aftermarket automotive clears cant match what the main stream companies produce (dupont, PPG, sickens, Standox )
mattsn is offline
Can I powder coat the hot pipe from turbo to intercooler? THEPISTONHEAD 2003-2007 6.0L Power Stroke 20 02-20-2008 03:43 AM
Looking for my Family Crest/coat of arms imported_LovinPSDs The Parking Lot 5 02-24-2007 03:23 PM
Can you use clear coat over spray paint? KarTek The Detailing, Paint & Bodyshop 4 01-22-2007 06:55 PM
Why 2K primer must flash between every coat regardless of when it will be sanded TooMuchBoost The Detailing, Paint & Bodyshop 0 04-09-2006 02:20 PM
Powder Coat blingage installed Dalpilot 2003-2007 6.0L Power Stroke 35 03-21-2006 11:38 PM
