Cleaning interior carpet - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Darsey715, this thread has received 3 replies and been viewed 2888 times.
post #1 of 4 (permalink) Old 01-14-2009, 07:05 PM Thread Starter
Hey guys, I'm wondering how many of you have removed all your seats and shampooed your carpets? How did it go and what products did you use/would you recommend? I'm thinking about just vacumming then putting some of that carpet powder down then vacuum again and then use my carpet shampooer on it. Thanks for any input.
2003 6.0 f250 ccsb 4x4 auto
Darsey715 is offline
post #2 of 4 (permalink) Old 01-14-2009, 07:08 PM
Check the detailing section, it's down close to the bottom of the home forum page.
justinlw is offline
post #3 of 4 (permalink) Old 01-17-2009, 01:25 AM
RussK's Avatar
I have done that a few times with different vehicles, I tried a lot of stuff but spray nine has worked the best for me. Not meant for carpets but they come out looking like new.
2001/05ish f250 Lariat 4x4 automatic, airaid intake, custom paint, 4 tan buckets’ covered in dead cow skin, wood dash & trim,gauges,elc trans cooler,Custom door sill lights (light up ground when door opens) Lots and lots of sound deadening other than that pretty much stock
Mercedes e320 (wife’s)
Nissan Maxima (work driver)
Dodge Magnum (work driver)
Trx 250r (off road adrenalin pump)
FORD 3600 diesel tractor
Singles club #164
american club # 9
I want to die while asleep like my grandfather,
not screaming in terror like the passengers in his car.
Russell
my truck from the begining
http://s391.photobucket.com/albums/o...um/my%20truck/
RussK is offline
post #4 of 4 (permalink) Old 01-17-2009, 12:27 PM
UpstateDieselGuy's Avatar
Thanks for the kind words I work for Spray Nine. What I always do is:
1 - Vacuum the carpet - Remove as much as you can with a good wet/dry vac.
2 - Agitate with a stiff bristled brush - this loosens up the burried soil and lifts it to the top.
3 - Vacuum again this will remove the loosened soil.
4 - Spray with cleaner - I know that I am a little biased, however I spray cleaner (Spray Nine) over the affected area and work it in with the same brush as used earlier.
5 - Wet it Down - This part is not for the weak using a hose with a fine mist or a trigger bottle wet the area down. NOTE: a little water goes a long way, dampen it, not saturate it! Once wet, use the brush to work the area. It will foam up and you can see the brown/black come out.
6 - Vacuum again - Once you have thoroughly worked in the cleaner/water mix use the wet/dry vacuum to extract the area. It will take several passes to pull the solution out. I would then apply clear water and vacuum again.
7 - Leave windows/doors open such that air can get to the area and dry it out.
I have done this for years with great success. I know that in the spring I have a healthy salt crust to remove and it works wonders.
Chris
SOLD
UpstateDieselGuy is offline
Interior cleaning and Protection StrokerDude The Detailing, Paint & Bodyshop 16 12-30-2008 04:36 AM
carpet???????? covey88 General Dodge Discussion 3 05-05-2008 11:24 PM
tired of the d***n carpet!!! 99stroke 1994-2003 7.3L Power Stroke 12 12-06-2007 03:31 PM
Sand in carpet POWER STROKE 99 The Detailing, Paint & Bodyshop 8 03-17-2007 11:24 PM
Carpet question 4cstr The Parking Lot 19 07-14-2006 02:31 PM
