Removing water spots/deposits - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kblackav8or, this thread has received 8 replies and been viewed 999 times.
post #1 of 9 (permalink) Old 01-16-2009, 04:53 PM Thread Starter
I do all my own stunts
Send a message via MSN to kblackav8or
While I was on deployment, my truck received some errant spray from a neighbors sprinkler. The water here in San Diego is pretty hard / laden with minerals. How do I get the white powdery water deposits off my truck now? When I was in Hawaii years ago there was this water spot remover stuff you could buy that worked pretty good. Does anyone know what I need to get?
Kevin
2000 F-250 PSD 6 speed 4x4 Lariat
1959 Kenworth CC 925 NTC-400 5x3 4.10 SQHD's
Myriad of parts and pieces in my garage
kblackav8or is offline
post #2 of 9 (permalink) Old 01-16-2009, 05:01 PM
I have a 2000 black Trans am and now a black 08 Expedition, and black 08 superduty. Looks like a funeral at my place sometimes. Anyways, I use a product called Scratch X which works awesome. Pretty much rub it on, let it dry to haze and wipe off.
Mr.Tourettes is offline
post #3 of 9 (permalink) Old 01-16-2009, 06:00 PM
plainredtruck's Avatar
Images: 11
Check out Adam's Polishes in our Vendor section. They have everything you need.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #4 of 9 (permalink) Old 01-16-2009, 06:59 PM
SLAPS President
teamroper60's Avatar
Images: 9
I'd start with a claybar and see how that does....... It might take polish to get them all off, but the claybar should help........
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #5 of 9 (permalink) Old 01-16-2009, 07:20 PM
Images: 11
A claybar is certainly the first thing you should do after washing, but I doubt it will make any significant difference.
You'll likely end up with a dual action polisher and several different pads and polish/wax combos to get it right.
BTDT.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #6 of 9 (permalink) Old 01-19-2009, 07:06 PM
Nitelord's Avatar
Images: 2
BTDT.
prt
I agree. The clay bar would be a great start, but you will likely be much happier with the followup polish and wax. Good luck...
2005 Ford F350 dually sb, wrapped in Black
Nitelord is offline
post #7 of 9 (permalink) Old 01-26-2009, 12:55 AM
JLWelding's Avatar
New to this but why not use vinegar. When I worked at a lime plant thats what we used.
JLWelding is offline
post #8 of 9 (permalink) Old 01-27-2009, 01:45 AM
Kyle`s Car Care
forrestk's Avatar
vinagar might hurt the clear i respect the opinion but i personally would clay then three step it clener polish than wax with a buffer. although dont high speed it unless you know what your doin
2006 Ford F-250 6.0L
forrestk is offline
post #9 of 9 (permalink) Old 02-04-2009, 03:26 AM
TDG #97
2008TTCC's Avatar
Vinegar just isnt the best choice... there are much better options out there!
I would start with clay bar... if that dont work move on to a light polish such as Meguiars #80... and then if need be go more coarse, but try the finest polish and see if it works. If your going for a perfect finish (mirror) with no spider webbing or halograms then just start with a coarse polish and work your way to a finer polish, ending with a sealant and then a LS wax (caranuba) for the depth
MAFIA #97
RIDIN' HIGH #28
RIDIN' DIRTY #40
SINGLES CLUB #203
B.O.M.B. SQUAD #67
2008TTCC is offline
Open Dyno spots January 5th in Indiana imported_Bosshawg600 Events and Gatherings 0 01-04-2008 04:52 PM
I've got some rot spots WNYPA The Detailing, Paint & Bodyshop 8 10-06-2006 05:56 PM
Rust Spots ALL over my truck hhrecovery The Detailing, Paint & Bodyshop 22 08-03-2006 06:56 PM
water spots nepsd General Ford Truck and Excursion 2 04-02-2006 12:06 AM
