How to Get That "Heavy Duty" Shine! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Junkman2008, this thread has received 18 replies and been viewed 2851 times.
post #1 of 19 (permalink) Old 03-09-2009, 06:22 PM Thread Starter
Detailing Devil Dog
Junkman2008's Avatar
I saw that Adam's Polishes is a supporting vendor here and had to share my personal experience with their products.
Just because you have a heavy duty rig and use it for heavy duty work, doesn't mean that you can't sport that heavy duty shine. Thanks to Adam's products, I sport that shine on my not so heavy duty ride. Although I don't roll like you big boys do over here, I think we all can agree that we want our rides looking good. Check out what you can do with a little elbow grease and the right products.
My latest victim is my 2001 Corvette Coupe.
Day 1
So I've been working on my ride and haven't had a chance to drive it since Christmas. It has just been sitting and collecting dust because I can't keep it covered and work on it at the same time. Just look at that dust!
I broke out my Adam's Polishes supplies and went at it. The first thing I needed to do is get the garage at a nice working temperature. I settled on the low 60's.
Next, I broke out my fire nozzle and rinsed all that dust off the car.
Then came the foam gun and the Adam's Car Wash.
Using a 4.1 ratio (4 parts water, 1 part Adam's Car Wash), I was able to get a nice soapy bath for my baby. So I soaked her down to get rid of any caked on dirt...
Got my Adam's Grit Guard wash bucket nice and full along with a another Grit Guard rinse bucket...
...and went at it. I cleaned her inside and out. One area that was really annoying me to death was the area under my fuel rail covers. It was dusty, dirty filthy and I couldn't take it anymore. So out came the Adam's All Purpose spray. I sprayed the area thoroughly and let it soak in. Then I rinsed it gently with water and blew it dry with my leaf blower. I must say, it came out rather well and for the first time, my belt didn't squeak one time after washing the engine!
So I dried her off and put her blanket on. Tomorrow I plan on going on a swirl hunt and putting some wax on her. Right now she's bare, but she still looks good.
Day 2
I told you all that I was going swirl hunting. Well I didn't have to search hard because I made the mistake of wiping the car down after a very light drizzle that I got caught in. The problem with doing so is the fact that dirt and grime had settled on the car from the drive and when I wiped the microfiber towel across the paint, I basically took some very light sandpaper to it. This is why I'm not big fan of the waterless wash products because if the car is not clean, you take a chance of doing exactly what I did.
Check out my before pictures:
IS THAT HIDEOUS OR WHAT?
So, I broke out my Flex and some Adam's Swirl & Haze Remover, some Adam's Detail Spray, my Adam's orange and white second generation pads, and a couple of microfiber towels. Here's a short video of the damage, as if the pictures are not enough.
This next video actually shows me doing one pass at the damage.
Here are a few things to note. I used a orange pad but could have used a white pad instead. Since my paint was in very good shape (thus easily damaged), I didn't necessarily need to get as aggressive as the orange pad. The white pad probably would have gotten rid of the damage just as effectively. As a rule, you want to go at a problem with the lightest, most effective method possible. Remember, you are shaving off the clearcoat so the less shaving you do is better for the paint.
If your paint is full of swirls and you have never done any paint correction, you will definitely need the orange pad. You will also need to clay the entire vehicle in order to rid your paint of contaminants.
Now for the results. Here's what the paint looks like now after my paint correction. As you can see, this is turning into quite a successful date!
Anything that you see that resemble a scratch is nothing more than a reflection off the pipes on the ceiling or something in the garage. This fender is now swirl free.
Once I get all the paint correction completed, I will hit the whole car with some Adam's Revive Polish. After that, I will come behind it with some Adam's Buttery Wax. I'll then wipe the whole thing down with some detail spray and cover her up and put here to bed. I probably won't get to drive here again for weeks so I'll just come down to the garage and peak under the sheets just to make sure she's okay.
Day 3
Okay, here's the final tally. I finally laid on the wax and pulled her out for some pictures just as it was getting dark. I'd say I'm happy with it! :bigthumb:
...and on the next day, I got some shots in the sun.
I really like how you can see the pearl in this picture. That's some clean paint!
The Junkman
Junkman2008 is offline
post #2 of 19 (permalink) Old 03-09-2009, 06:35 PM
bushpilot's Avatar
DAMM...65 bucks for a wash bucket & another 100 bucks for a foaming hose nozzle !
Don R.
Truck Audio,
bushpilot is offline
post #3 of 19 (permalink) Old 03-09-2009, 06:53 PM Thread Starter
Detailing Devil Dog
Well, you have to understand how the wash bucket works. This is not for the casual car care person, this is for the person who wants their ride to shine like glass. This thread explains it somewhat. I thought the same thing you posted back when my car was full of swirl marks. Now I know better!
post #4 of 19 (permalink) Old 03-09-2009, 07:14 PM
bushpilot's Avatar
I get it, theres a guard at the bottom that lets the dirt fall to the bottom,
where a sponge or mit cant pick it up.
Im a sucker for QUALITY TOOLS...and their stuff is neat...but damm its
a 5 gallon bucket w/ some casters & a grid in the bottom...if theres more
than 10 dollars in material there i would be shocked.
Don R.
Truck Audio,
The Following User Says Thank You to bushpilot For this addition to TDG:
99_stroker (05-22-2009)
post #5 of 19 (permalink) Old 03-09-2009, 07:27 PM
Nitelord's Avatar
Images: 2
AJ. Thanks for posting your pix and video's. You are a detailing mad man.
The bucket is not the key here folks. Any 5 gallon bucket will work. However, don't decide to use the one that was leftover from sealing your driveway. At least get a new one that is clean to start with. The grit guard will fit in the bottom and the caddy (if you decide to purchase it, will work on the generic bucket. The gun is worth every penny.
AJ's willingness to sign up and post his write up is very much appreciated. Thanks again... -Mark
2005 Ford F350 dually sb, wrapped in Black
Nitelord is offline
post #6 of 19 (permalink) Old 03-09-2009, 08:53 PM
The DUDE!!
sprman's Avatar
I AGREE with you Don, hey finally we agree on something, but the guard by itself would be something i would consider.
It might be worth every penny, but would be pointless for big trucks like mine. There is no way that i would be able to soap my entire truck down and get the entire thing washed before the soap either fell off or dried up. I have to do a section at a time and rinse. Then move the ladder and repeat. Now if i had a bad azz vette, it would be pretty sweet to have.
This thread reminds me, i need to order that little grit guard thingy. I've been meaning to for awhile now and it's starting to get that time of year where i can keep the truck clean.
2005 F-250 CC FX4 - bought it, changed some stuff
Eighty Sixed member - #3
Ridin' Dirty - #26
"All the oil is in TEXAS, but the dipsticks are in DC"
"If Obama is the answer, it must have been a stupid a** question......"
sprman is offline
post #7 of 19 (permalink) Old 03-09-2009, 09:37 PM Thread Starter
Detailing Devil Dog
I understand Ron, I'm a sucker for quality tools too!
You can get just the inserts for $10 right here. I've seen big wash buckets at Wal-Mart and you don't have to get the caddy. I'm just lazy and get tired of picking up the buckets (I use two, a wash and a rinse bucket), and moving them around the car. Yea, I'm lazy.
Hey Mark, fancy seeing you over here! I didn't think that I would run into someone I kinda knew!
post #8 of 19 (permalink) Old 03-10-2009, 03:29 AM
Nitelord's Avatar
Images: 2
Hello AJ, Welcome. I spread myself pretty thin these days. TDG, DB, DC and AF take up the majority of my online time. I've got two others that I moderate and one forum I admin. I get around a bit. See you on AF.
Nitelord is offline
post #9 of 19 (permalink) Old 04-14-2009, 09:09 AM
Superdutytd's Avatar
Images: 3
Hey AJ what pads are you using with your flex?
2008 Red CCSB 6.4 Auto Lariat.
Stock 20's wrapped in 35x12.50R20 Toyo MT's, 3.73 gears, Nav, Backup Cam, Tailgate step, Upfitters, etc.
Mods: AFE Intake, Line-X, 20% Tint, Clear Bra, Husky Mats, Smoked Recon Mirror markers/3rd brake light, Bushwacker Pocket style flares w/ mud flaps + an aluminum Rapid Hitch (one of the best investments!)
Feel free to PM with any questions about any of my mods.
SRW Club #55
American Club #55
Last road trip-567 miles @ 20.7 mpg @ 67mpg average speed.
Superdutytd is offline
post #10 of 19 (permalink) Old 04-14-2009, 12:11 PM Thread Starter
Detailing Devil Dog
Those are the Adam's second generation pads.
"Marines - Making the other guy die for his country for over 200 years."
The "New Diesel Emissions" prevent the use of a "Jacobs" (jake brake) HARLEY6LF250SDU General Diesel 4 01-17-2009 02:53 PM
38"x15.5" Toyo MT's on 20"x10" XDdiesels-$2,000.00 sschoppa Whats Been Sold 3 01-20-2008 03:38 PM
TO joe "csipsd" and Chelsea "cdiesel" moose99psd The Parking Lot 29 04-28-2007 03:57 AM
"thud" or "thump" underhood please help 6LTR4LIFE 2003-2007 6.0L Power Stroke 4 12-20-2006 04:24 PM
NBA Headlines Ford: A new No. 1 contender<img src="http://espn.go.com/i/in.gif" width="11" height="11" hspace=4 border="0" alt="Insider"> RSS Feeder The Parking Lot 0 06-09-2006 07:00 AM
