Wet Sanding 101 - The Videos - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Junkman2008, this thread has received 2 replies and been viewed 901 times.
post #1 of 3 (permalink) Old 03-14-2009, 02:41 PM Thread Starter
Detailing Devil Dog
Junkman2008's Avatar
You've asked for it, The Junkman delivers! :
First off, let me say that everything I've learned about wet sanding was developed by reading a bazillion articles on the Internet, practicing on my daily driver, and screwing up my Corvette once (very costly mistake I might add ). With that said, I want to make sure that you understand that I am by no means an expert at this. However, I am able to save myself hundreds of dollars by repairing damage to my ride that you would normally have to pay a skilled detail individual to do. What you will see in the following videos is a successful attempt at removing a scratch that was too deep to remove with a buffer and compound.
There are 2 resources that I used heavily to research this practice. One is Kleen Car Auto Appearance, which is a car detailing site that sells video how to's on car detailing, as well as offers classes on the same topic. The other is Mobile Works which also has a lot of information on this topic.
Now, before you even think about taking these extreme measures to repair damage to your car, there is one tool that is required to do this correctly, and there is some very important information you need to have BEFORE you start. The tool you must have is a paint thickness gauge. A good paint thickness gauge will measure the amount of clear coat AND paint that is on the car. The Corvette being fiberglass requires a paint thickness gauge capable of taking readings off of fiberglass. Without this, you are just guessing when you wet sand. If you don't know what you're doing and you start guessing on your pride and joy, you'll probably end up at a paint booth near you, spending some dead presidents to fix your screw-up. Thus, you should never practice on your pride and joy. Use your wife's hooptie or your girlfriends clunker to get good at this and then move up to your pride and joy. I've been practicing this for a year now and I still am VERY careful when fooling with my ride.
Car manufacturers has a set standard with how much clear and how much paint they put on a car. I don't know what that standard is but once you have your car painted, that changes of course. So if you do decide to get your ride painted, you may want to find out what that ratio is from the person who is painting your car.
I don't want to duplicate a lot of the reading that you will end up doing if you follow the links that I've provided so I'll just post the videos. Remember, you must utilize the links that I have provided in conjunction with the essential tools needed in order to be successful at this. Do not do as I do, do as I say! One wrong stroke of the sandpaper can be catastrophic for your paint job! If you decide to do this, know that you do so at your own risk and I assume no responsibility for your inexperience. This is something that is best left to a experienced individual, or to those who just have money to burn! I am neither, just ballsy.
I now use Adam's Polishes to do all of my polishing and waxing. Keeps me from having to order products from all over the place and their products are outstanding (their customer service can't be matched!). If you need details, just post up in this thread and I'll supply the information.
Here's the videos:
(Be sure and choose the "high quality" link so that you can see the process in very good detail, and my ugly mug in all its glory... )
Here's some before and after pictures of another area that I was working on. The scratches were on the rear quarter and near the top of the door handle. The after pictures are just after I used the fine cut cleaner. There is no polish on the car yet.
The Junkman
Junkman2008 is offline
The Following 3 Users Say Thank You to Junkman2008 For this addition to TDG:
CrowsSynthetics (03-14-2009), fordt (03-17-2009), Superdutytd (03-16-2009)
post #2 of 3 (permalink) Old 03-14-2009, 02:48 PM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
I have always wanted to know how to do this.
Thanks Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #3 of 3 (permalink) Old 03-14-2009, 02:52 PM Thread Starter
Detailing Devil Dog
Thanks Bill
Glad to be of help.
"Marines - Making the other guy die for his country for over 200 years."
wet sanding? ipkyss The Detailing, Paint & Bodyshop 10 03-24-2009 09:15 PM
Wet sanding black paint? D-Man The Detailing, Paint & Bodyshop 11 04-08-2007 01:49 PM
Wet sanding? WNYPA The Detailing, Paint & Bodyshop 9 04-27-2006 10:32 PM
Wet Sanding hhrecovery The Detailing, Paint & Bodyshop 5 04-19-2006 11:14 AM
Wet sanding and buffing trick TooMuchBoost The Detailing, Paint & Bodyshop 4 04-14-2006 01:27 AM
