Under the hood - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bcarriveau, this thread has received 30 replies and been viewed 3328 times.
post #1 of 31 (permalink) Old 03-16-2009, 11:44 PM Thread Starter
********* and Mafia #90
Bcarriveau's Avatar
Under the hood
what do you guys use to wash your motors that does not leave white residue behind??? Used some Super Clean crud from Ace and it cleaned but left white behind on almost everything, especially on the aluminum I rinsed very very well..
Thanks in advance..
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #2 of 31 (permalink) Old 03-16-2009, 11:47 PM
Diesel Mafia #67
blackcloudCTD95's Avatar
........? who washes there motor? its just going to get covered in oil in 10 mi's , No I did it once and I used gunk ,engine degreaser let it sit for 10 mins hosed it off then used tire shine....
Jordan
blackcloudCTD95 is offline
post #3 of 31 (permalink) Old 03-16-2009, 11:52 PM Thread Starter
Bcarriveau's Avatar
Who the hell let the peanut gallery in
My motor has 80K on it very very very little oil on it, maybe you need to check your seals
No anyone have some useful info, im looking for more of a wash then a degreaser..
Thanks in advance for guys that give useful info
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #4 of 31 (permalink) Old 03-16-2009, 11:58 PM
myf350's Avatar
Simple Green seems to work good for me.
SOLD...early 99 F350 CC 4WD SRW, Tymar intake, 4 in. turbo back straight pipe w/ 5 in. tip, DP tuner, 203 t-stat, Timbrens in the rear, front leveled, King Ranch wheels, ISSPro gauges, Weston brush guard, rebuilt my trans using a Torqueshift converter
08 CC LB DRW MT 4WD Ranch Hand bumpers...stock for now
myf350 is offline
The Following User Says Thank You to myf350 For this addition to TDG:
Bcarriveau (03-17-2009)
post #5 of 31 (permalink) Old 03-17-2009, 12:00 AM
Diesel Mafia #67
if you want to clean it up a bit, Just soap and water, 409/ simple greem and armoral
And its my front main seal thank you, only leaks when put under 30psi or more. :
Jordan
The Following User Says Thank You to blackcloudCTD95 For this addition to TDG:
post #6 of 31 (permalink) Old 03-17-2009, 12:07 AM Thread Starter
Bcarriveau's Avatar
i hear simple green is good, keepem coming guys.. ..
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #7 of 31 (permalink) Old 03-17-2009, 12:17 AM
Wanna be door swinger
pullingtrucker's Avatar
Send a message via Yahoo to pullingtrucker
Simple green works. But I perfer to use a pressure washer with hot water. I degrease the under side of my Pete every year and it does the trick.
'06 379 Peterbilt with a C-15 MXS 550hp, 200gph FASS, high flow mufflers, fuel harness, shimmed fuel pump, crankshaft balancer, Bully Dog Big Rig downloader, Bully Dog exhuast manifold, Spinner II bypass filter , a big Detroit Radiator, custom built Lipe clutch, Schaeffer's synthetics in all boxes, and a 18 speed tranny.
'06 53' Utility 3000R with a Carrier unit hanging on the nose. Just a plain trailer with little frills.
Ridin Dirty Club #12
pullingtrucker is offline
The Following User Says Thank You to pullingtrucker For this addition to TDG:
post #8 of 31 (permalink) Old 03-17-2009, 12:25 AM
fine69's Avatar
I use Simple Green then this http://www.maximausa.com/products/cleaners/sc1.asp Some Armor All type tire shines seem to mess up rubber hoses from what I've seen. The SC1 makes it a breeze to clean up the next time and leaves an incredible looking engine bay.
H-M.W.H. Club #2
Union Club #1
Singles #237
B.O.M.B. Squad #12
Ridin' Dirty Club #17
American Club #15
fine69 is offline
The Following User Says Thank You to fine69 For this addition to TDG:
post #9 of 31 (permalink) Old 03-17-2009, 12:31 AM
X2, just get the spray bottle at wally world and don't add water. Also works great on tire, plastic, flormats, getting soot off your tips or stacks and alot more. NEVER EVER use purple power on your truck, motorcycle or anything with aluminum, it messed up my old race bike's motor (looks). Also the dollar store has "super mean green" that works really well.
05 F-250 FX44"superlift, 35" pirelli scorpion ATR"S, sirius satellite radio, 1 sony 10" with 1k watts. sct with spartan and Doug's tunes, bullydog outlook, coolant temp, Egrcooler delete, coolant filter, 4" exhaust to 5" stacks, B&W gooseneck hitch, limo tint, ARP studs. AFE stageII intake with PG7, VIPER 5900SST
RIDIN' DIRTY member #23
Bomb Squad member #49
Running motor and trany with all wires, computers, ic, programmer and outlook will be forsale! PM with offer.
stacks is offline
The Following User Says Thank You to stacks For this addition to TDG:
post #10 of 31 (permalink) Old 03-17-2009, 01:31 AM
SLAPS President
teamroper60's Avatar
Images: 9
I've used Simple Green a couple of times. But years ago, I used to use powered laundry detergent too....... Sprinkled it on, then a heavy mist of water to suds it up, let it sit about 10-15 minutes and rinsed off...... It worked pretty well on my gassers. Haven't tried it on the diesel..... Since the second time I used Simple Green, I just haven't let it get very dirty...........
To make it shine, I used to use Armorall or something similar....... Now I am using Adams's stuff. I like it much better but it is costly.....
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
The Following User Says Thank You to teamroper60 For this addition to TDG:
new hood mxchase General Ford Truck and Excursion 4 02-24-2011 07:05 AM
Under hood pic superf350 2003-2007 6.0L Power Stroke 24 11-26-2006 02:32 PM
New Hood SpicyJam Dodge Performance Forum 7 04-26-2006 10:53 AM
Whose 747 under the Hood? Rick65 Video Discussion & Support 1 04-23-2006 11:51 PM
New Hood umcgrad 2003-2007 6.0L Power Stroke 5 03-21-2006 08:00 PM
