buffer help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SSpeeDEMONSS, this thread has received 10 replies and been viewed 2135 times.
post #1 of 11 (permalink) Old 03-20-2009, 06:25 PM Thread Starter
SSpeeDEMONSS's Avatar
buffer help
so i have a craftsman buffer at my house and the Adams velcro wheel wont fit on it as they are different. what kind of buffer do i need to get the adams wheel to fit on it?
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #2 of 11 (permalink) Old 03-20-2009, 06:56 PM
plainredtruck's Avatar
Images: 11
Is the craftsman a buffer or an orbital polisher?
You need a backer plate for the buffer, if that's what it is. Most any auto body supply store should have them readily available.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 11 (permalink) Old 03-21-2009, 04:17 AM
Detailing Devil Dog
Junkman2008's Avatar
You need a PC-7424. Look here. Best price I've seen! From what Sears is offering, you either have a totally worthless buffer or way more buffer than you even want next to your paint. Which one did you buy?
"Marines - Making the other guy die for his country for over 200 years."
Junkman2008 is offline
post #4 of 11 (permalink) Old 03-21-2009, 05:16 PM Thread Starter
http://www.sears.com/shc/s/p_10153_1...+%26+Polishers
it works good but i have Adams stuff now so i want something that works with it best.
post #5 of 11 (permalink) Old 03-21-2009, 05:25 PM
Images: 11
Buffers have their place, but I doubt you need that Garrett.
You can burn your paint in a hurry with one if you aren't very careful.
Junkman's correct on the dual action polisher. Once you use one, you won't want anything else.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #6 of 11 (permalink) Old 03-21-2009, 06:00 PM
Detailing Devil Dog
prt
I big time agree. That thing will ruin your paint in a heartbeat. That polisher is for professionals. I won't even pick up one of those and I know what I'm doing.
post #7 of 11 (permalink) Old 03-22-2009, 04:59 PM Thread Starter
well that sucks, i have used it several times on the truck with good results.
post #8 of 11 (permalink) Old 03-23-2009, 01:49 AM
Images: 11
I'm glad to know you're having good results, but a dual action will give you better result with less work.
Now, with that said, if you choose to stick with the buffer, you still need a backer pad. I stand by my earlier post that you should be able to find one at any auto body supply shop.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #9 of 11 (permalink) Old 03-23-2009, 01:53 AM Thread Starter
prt
yeah, ill probably get the PC.
post #10 of 11 (permalink) Old 03-23-2009, 02:01 AM
Detailing Devil Dog
prt
Actually, it's the other way around. The polisher he has makes quick work of any kind of paint imperfection. The problem is that it can remove the imperfection and the paint with it! A orbital polisher does not have the RPM's needed to remove the paint short of you leaving it on the car and nailing it down overnight. That's why a orbital is also so safe. That, and the fact that a orbital's pad action keeps it from sitting in one spot on the car. These are the two main reasons a novice should start out on a orbital.
Check out the difference in the pad action between the two:
Keep in mind that the orbital is also spinning while making the large orbits in the picture above.
The Following User Says Thank You to Junkman2008 For this addition to TDG:
Nitelord (03-23-2009)
buffer suggestion CAMSBLUE04 The Detailing, Paint & Bodyshop 5 02-25-2008 08:34 PM
Finally got to use my new buffer... Zaairman The Detailing, Paint & Bodyshop 9 11-23-2007 11:09 PM
Absolute best polisher/buffer? WNYPA The Detailing, Paint & Bodyshop 25 08-16-2006 05:21 PM
Buffer or polisher tjl The Detailing, Paint & Bodyshop 12 04-12-2006 11:26 PM
