Used Motor oil - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by neeltburn, this thread has received 2 replies and been viewed 874 times.
post #1 of 3 (permalink) Old 05-24-2009, 01:46 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Used Motor oil
So my dad was taking in our old motor oil when the lid came off one of the buckets and sloshed about 1/2 gal into the bed of his truck...the rubber bed mat seems to be trashed and the plastic drop in liner is almost cleaned. after 2 hrs of cleaning on it, it is almost clean..is the something to put on the rubber bed mat to clean it..Im gonna try comet this weekend and wash and wax the whole truck is there a certain product they will clean this up really good, or any advise..
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #2 of 3 (permalink) Old 05-24-2009, 12:28 PM
UpstateDieselGuy's Avatar
Try a heavy duty degreaser. I know many will laugh, but I have had good luck with Dawn dish detergent even. Also, use hot water if possible. Chris
SOLD
UpstateDieselGuy is offline
post #3 of 3 (permalink) Old 05-24-2009, 08:05 PM
Repository of Diesel Info
Make sure to under the bedliner if any got thru. Dawn and hot water does work really well. You will probably have to get a new plastic mat if it soaked any up.
Haloman is offline
need motor hwm 7.3L and 6.9 IDI (Pre 1994) 2 05-12-2009 07:11 PM
What to do while motor is out? 4wydnr Diesel Conversion 9 02-08-2009 07:00 PM
Motor tbroadus_41 5.9L Cummins 12 Valve (1994-1998.5) 5 11-15-2007 04:19 AM
What CAT motor was in this? Duke Utility & Farm Tractors 16 02-13-2007 06:56 AM
new motor BogginF350 Sled Pulling 2 01-20-2007 12:58 PM
