Bed Linear Prep - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Super08Duty, this thread has received 11 replies and been viewed 1668 times.
post #1 of 12 (permalink) Old 06-29-2009, 02:13 AM Thread Starter
Diesel Kid
Super08Duty's Avatar
Question Bed Linear Prep
Im Thinking about putting herculiner on my Factory chrome bumpers. But i need some suggestions on how to prep them. And i want the prep to be very well so the bed liner stays on there.
Should i use an Orbital Pneumatic Sander or a grinder with a sanding pad or should i sand blast it? Do I need to use some sort of primer before the bed liner? Im lost, At this point all I know is that the chrome has to come off the bumper before the bed liner goes on it.
Colton
2008 F-250 PSD 4X4 XLT
Spartan-MBRP-Elite-AFE-KEM
542hp 1060trq 9/18/10
Super08Duty is offline
post #2 of 12 (permalink) Old 06-29-2009, 02:19 AM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
get aggressive...grinder...60 grit,...scrape the chit out of it...
I used a grinder with a flapper disc on it, on my stock rear bumper.
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
The Following User Says Thank You to TANK'S 250 For this addition to TDG:
Super08Duty (06-29-2009)
post #3 of 12 (permalink) Old 06-29-2009, 03:27 AM Thread Starter
Diesel Kid
So after you grind it down real good and wipe it down clean do you use some sort of primer or just slap it on there?
Colton
post #4 of 12 (permalink) Old 06-29-2009, 03:31 AM
TANK'S 250's Avatar
Images: 38
I didn't used any primer,...I just used alcohol to clean it up real good,....then started rolling..
Special thanks to:
KLMperformance.com
Black Ops Bumpers
post #5 of 12 (permalink) Old 06-29-2009, 03:34 AM Thread Starter
Diesel Kid
Awesome, one more question. Did you take off all the plastic and roll the entire bumper or did you mark it off and only roll the parts that would not be covered by plastic? Like where you would normally see the chrome.
Colton
post #6 of 12 (permalink) Old 06-29-2009, 03:37 AM
TANK'S 250's Avatar
Images: 38
I removed everything,...plastics, license plate lights,...everything
Special thanks to:
KLMperformance.com
Black Ops Bumpers
post #7 of 12 (permalink) Old 06-29-2009, 03:43 AM Thread Starter
Diesel Kid
cool, so you rolled it all then?
Colton
post #8 of 12 (permalink) Old 06-29-2009, 04:06 AM
TANK'S 250's Avatar
Images: 38
yes....only use the roller,..that is the only way r;j ti r ;hs...
screw it,..I'm done typing,..call me if you need more info......I hate typing.
504-915-7841.....
Special thanks to:
KLMperformance.com
Black Ops Bumpers
post #9 of 12 (permalink) Old 06-29-2009, 04:07 AM
TDG Mafia Goon
BombDocDiesel's Avatar
When they sprayed the bedliner in my trucks they scuffed it, wiped it down with thinner and sprayed. The chrome may require #80 on an orbital or DA if you have air.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
The Following User Says Thank You to BombDocDiesel For this addition to TDG:
post #10 of 12 (permalink) Old 06-29-2009, 04:10 AM Thread Starter
Diesel Kid
I think i got it Tank. Thanks guys.
Colton
Trip to daytona. Prep PowerChoker32 1994-2003 7.3L Power Stroke 20 01-23-2008 06:20 PM
Prep Pump Mod Rusty-Carlton 1994-2003 7.3L Power Stroke 3 05-23-2007 03:06 PM
AFE prep before install kkibbey 2003-2007 6.0L Power Stroke 4 11-11-2006 02:31 AM
Online tax prep miscalculation TooMuchBoost The Parking Lot 2 02-07-2006 02:08 PM
