Paint Code - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by wastedwagesracing, this thread has received 9 replies and been viewed 5114 times.
post #1 of 10 (permalink) Old 08-14-2009, 12:03 PM Thread Starter
Banned
Paint Code
Does any one know where to find the paint code on an 05 Superduty??
wastedwagesracing is offline
post #2 of 10 (permalink) Old 08-14-2009, 04:07 PM
mattsn's Avatar
its on your infomation sticker on your drivers door jamb. lower left hand corner it should say EXT PNT then under that or sometimes it just to the right of that should be a 2 digit code . if you are asking about the truck in your avatar it looks black and the code for black is UD .
mattsn is offline
post #3 of 10 (permalink) Old 08-15-2009, 04:36 AM Thread Starter
Banned
Thanks, also do you know if Ford only used one color of black..I was told once that they used three different black paint codes in the same year.
post #4 of 10 (permalink) Old 08-15-2009, 04:43 AM
********* and Mafia #90
Bcarriveau's Avatar
Exterior paint codes may be listed as a two-part code. The first set of characters listed indicate the vehicle primary body color code. The second set of
characters listed (if applicable) indicate a two-tone or accent body color code.
Primary Body Color
- AQ - Arizona Beige (clear coat)
- CX - Dark Shadow Gray (clear coat)
- D6 - Screaming Yellow (waterborne) clear coat
- E4 - Vermilion Red (clear coat)
- F1 - Vermilion Red (waterborne) clear coat
- FL - Medium Toreador Red (clear coat)
- FW - Dark Satin Green (waterborne) clear coat
- JM - Dark Toreador Red (waterborne) clear coat
- L2 - True Blue (waterborne) clear coat
- LD - Medium Wedgewood Blue (clear coat)
- P - Stripped chassis paint (DSO)
- T5 - Dark Copper (waterborne) clear coat
- T7 - Charcoal Beige (waterborne) clear coat
- UA - Ebony (clear coat)
- UD - Ebony (waterborne) clear coat
- YN - Silver Metallic (clear coat)
- YZ - Oxford White (clear coat)
- Z1 - Oxford White (waterborne) clear coat
- Z3 - Silver Metallic (waterborne) clear coat
Two-Tone Color
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #5 of 10 (permalink) Old 08-15-2009, 04:47 AM Thread Starter
Banned
So then it looks like there is only one Black...
post #6 of 10 (permalink) Old 08-15-2009, 10:28 AM
mattsn's Avatar
there used to be another code for Black, It was UA . I am pretty sure they dont use it anymore because it is a much Browner shade of black when compared to UD . if you tell me the year and model of the vehicle your are looking for ill verify the code for you. even if you have UA you can probably get away with using UD . most people can not pick up the difference with there eyes.
Bill is right if the vehicle is 2 toned then the lower color will be to the right of the primary color code. But Ford is a pain in the A** and does not always put the secondary/lower color code on the label .
Bill the list of codes you posted are older colors. many of those are not used anylonger. such as AQ has been replaced with G2 . couple others are not used any longer. not sure if you have an updated list incase you need to post one in the 08 forum
mattsn is offline
post #7 of 10 (permalink) Old 08-15-2009, 02:07 PM Thread Starter
Banned
Matt thanks. The only reason I'm wondering is that before I took delivery of my truck some goof at the dealer dinged up one of the rear fenders. They painted it but it never looked right. I took it to a different dealer to be fixed. They told me that it was because the other dealer used the wrong paint code. He said Ford uses three different blacks. The one on my truck has some yellow in it. I'm looking at a used topper that is for sale on here. And we are just trying to figure out if the color is going to match or not.
post #8 of 10 (permalink) Old 08-15-2009, 04:09 PM
Bcarriveau's Avatar
that's a list for 05, not sure what year dougs truck is as he fails to tell us in his signature .. I have the 07 list as well and it looks the same, wonder when they axed it..
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #9 of 10 (permalink) Old 08-15-2009, 05:04 PM Thread Starter
Banned
Yup it's an 2005...
post #10 of 10 (permalink) Old 08-15-2009, 10:59 PM
mattsn's Avatar
new colors came out in 08
Doug, it is possible they sparyed the wrong black. alot of people and even painters think black is black. if you can see the difference then you can see color better than alot of people .
also , most paint companies have there "super black" its basically a "true" black and it is usually blacker than factory blacks ( specifically its bluer ) many painters just go straight to that when a black car comes through. it saves them the 5 mins it takes to mix up the formula that they should be mixing.
mattsn is offline
The Following User Says Thank You to mattsn For this addition to TDG:
wastedwagesracing (08-15-2009)
Paint code rsjohnsn The Detailing, Paint & Bodyshop 2 08-04-2009 10:40 AM
paint code help newtodiesel General Ford Truck and Excursion 1 02-15-2009 09:06 PM
where to find my paint code?! jakebrakeIH General GM Truck Forum 2 11-29-2007 04:21 PM
'97 Ford paint color/code Illini Ram General Ford Truck and Excursion 1 06-09-2007 02:09 AM
Ford Z1 oxford white paint code fastback4 The Detailing, Paint & Bodyshop 0 11-16-2006 03:27 PM
