need layout of pistons crossin - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97CumminsTurboDiesel, this thread has received 12 replies and been viewed 1648 times.
post #1 of 13 (permalink) Old 09-15-2009, 03:00 AM Thread Starter
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
i had a wicked idea i was thinkin of havin stroke this on my back tailgate and havin on both side pistons crossing but i was thinking of removin the back plastic peice on my tail gate and i also need some info on paint and sand paper the truck is a 2 tone white and gray i was gonna paint the tailgate white but could i go ahead and just use a good can of spray paint, i want it look professional but i dont wanna tie too much money into it either but i was gonna try to get it done before the truck pull which is the 2nd and 3rd next month but any suggestions is greatly appriacated!
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #2 of 13 (permalink) Old 09-15-2009, 12:37 PM
mattsn's Avatar
Do you mean you wanna paint the pistons on also? If you want a professional job you can not use spray paint
mattsn is offline
post #3 of 13 (permalink) Old 09-16-2009, 04:52 AM Thread Starter
yea air bruise it on, i noticed they had a small paint job almost like a airbruise but i dont know nothin bout paint guns or body work or painting in general but i dont wanna spend a whole alot tho
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #4 of 13 (permalink) Old 09-16-2009, 05:57 AM
lilpooh's Avatar
what about vynal grphics.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #5 of 13 (permalink) Old 09-16-2009, 10:47 AM
mattsn's Avatar
if you dont wanna spend much $$$ then i would suggest vinyl also.
mattsn is offline
post #6 of 13 (permalink) Old 09-18-2009, 02:20 AM Thread Starter
yea i havent thought bout that too much but ill get some prices on it and what do i need to do to prep that tail gate what would be good sand paper to get off the old paint and so on
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #7 of 13 (permalink) Old 09-18-2009, 02:39 AM
lilpooh's Avatar
if your talking about the vynal grphics, no sand paper just get clean and put on like the vynal window stickers.just have to be careful to get all the air bubbles out.
lilpooh is offline
97CumminsTurboDiesel (09-20-2009)
post #8 of 13 (permalink) Old 09-18-2009, 10:40 AM
mattsn's Avatar
right no need to remove paint if you go with a decal.
mattsn is offline
post #9 of 13 (permalink) Old 09-19-2009, 01:02 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
where are you located in VA???
2003 F250 "Pulling Truck"
hhrecovery is offline
post #10 of 13 (permalink) Old 09-20-2009, 03:38 AM Thread Starter
the thang is i had to do some work on it where its beated up and all im like well i might as well try to paint it and make it look good
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
1997 engine compartment fuse box layout POWER STROKE 99 1994-2003 7.3L Power Stroke 4 05-05-2009 11:54 AM
06 fuse layout dangerous196 5.9L Cummins (2003-2007.5) 1 03-08-2008 02:04 AM
Battery Cable Layout genie144 1994-2003 7.3L Power Stroke 0 08-23-2007 10:37 PM
Shop Layout. Blueprints. Smokem 5.9L Cummins (1998.5-2002) 19 07-10-2007 02:48 AM
