Spiderwebbing fiberglass - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Paccar Cat Nothing Else, this thread has received 4 replies and been viewed 1183 times.
post #1 of 5 (permalink) Old 01-14-2010, 01:17 AM Thread Starter
Paccar Cat Nothing Else's Avatar
Ok, so I am restoring a 74 Kenworth A-model, which has a fiberglass hood and roof caps with all of the spiderwebbing you expect to go along with it. the owner wants me to paint it for him. I have painted several cars and semi's but i'm not sure what the best solution is for the spiderwebbing. I have heard of a sort of gel coat that you can spray on to resurface it, but I don't know anything about who makes it or how it holds up. I would really appreciate any info or tips that can help me. This truck is a huge project and I don't want to disappoint. Thanks.
Paccar Cat Nothing Else is offline
post #2 of 5 (permalink) Old 01-15-2010, 11:18 PM
mattsn's Avatar
is the spider webbing only in the paint or is it in the Glass? the only "spray on gel coat" that I know of is actually a Sprayable Polyester. they work awesome but im not sure how it would do if the Webbing is in the Glass.
if you choose to try it, I like to use a product by "Ever Coat " called " slick Sand " i love it for high build and when i need something that will absolutely not Shrink. its pretty cheap but whatever you do... Do not Thin it out. use a gun with at least a 1.8 tip and really open it up and crank your pressure up .
There are a few other versions/ brands of sprayable polyesters. Dupont makes one for Their Nason line and I think PPG does aslo. Stay away from one called Feather Fill . and do not thin them. some of them claim that you can thin them with a Urethane reducer but i have found that they do not work as well.
mattsn is offline
post #3 of 5 (permalink) Old 01-15-2010, 11:19 PM
mattsn's Avatar
mattsn is offline
post #4 of 5 (permalink) Old 01-16-2010, 12:29 AM Thread Starter
Ok. Thanks for the info. I'm not positive as to whether or not it is into the fiberglass. I'll have to check. I'm kinda afraid that it is. Any suggestions if it is? In the past, I've ground the fiberglass down til I'm past the crack and then use filler to build it back up. However, this is a whole lot bigger area than I normally have to deal with. But I'm more of a mechanic than a body man and I didn't know if there was any better solutions out there. Thanks again.
post #5 of 5 (permalink) Old 01-16-2010, 12:30 PM
mattsn's Avatar
yeah, if its in the glass the only way to fix it for good is to grind it out. I wouldnt use filler to fix something like that .
best thing might be too look into a new/used part. i know thats probably alot more than this guy wants to spend but compared to the cost of paying your labor in fixing it correctly (if its into the glass ) a new hood might work out to be not so expensive .
I myself dont have tons of experience with fiber glass work . i wonder if you could contact a boat repairer or a body shop that deals with the big trucks. See if they have any magic potion i dont know about
mattsn is offline
fiberglass lower valance powerstrokin06 7.3L and 6.9 IDI (Pre 1994) 0 10-30-2006 04:06 AM
Fiberglass hood for a 1988 9 Lives 7.3L and 6.9 IDI (Pre 1994) 2 10-12-2006 06:58 AM
When fiberglass isn't fiberglass TooMuchBoost The Detailing, Paint & Bodyshop 2 04-12-2006 03:25 AM
Fiberglass Tonneau Fantom3993 Supporting Vendors Forum 8 02-03-2006 02:12 PM
Wanted Fiberglass Tonneau 06 SuperDuty Whats Been Sold 0 01-25-2006 03:55 AM
