Aluminum polish and pitting repair - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by thesmokinstroke02, this thread has received 11 replies and been viewed 8136 times.
post #1 of 12 (permalink) Old 03-23-2010, 11:21 PM Thread Starter
Hadley Coal Roller
thesmokinstroke02's Avatar
is there any way to repair pitting on mickey thompson classic locks? mine are a little black in some areas. also what are some good polishes?
-Konnor-
Dark Grey 02 F-350 4x4 CC SB
Diesel Innovations 6pos Chip
DIY intake
Autometer C2 Gauges
Sky Manufacturing leveling kit
35" pro comps with mickey thompson classic locks
B.O.M.B Squad #75
Ridin' Dirty #19
American Club #75
Riding High Club #19 (The Dodge Got this one)
"Northern by birth, Southern by heart"
thesmokinstroke02 is offline
post #2 of 12 (permalink) Old 03-24-2010, 10:20 AM
mattsn's Avatar
only way to remove pitting is to re surface the wheels. there are wheel repair shops that can do this and it isnt very expensive considering how awesome they look when you get them back.
adams has a good polish ( metal polish ) I like Mquiers latest one also .
mattsn is offline
The Following 2 Users Say Thank You to mattsn For this addition to TDG:
Nitelord (03-24-2010), thesmokinstroke02 (03-24-2010)
post #3 of 12 (permalink) Old 03-24-2010, 02:12 PM Thread Starter
Hadley Coal Roller
thanks. good lookin truck as well
-Konnor-
DIY intake
Autometer C2 Gauges
B.O.M.B Squad #75
Ridin' Dirty #19
American Club #75
post #4 of 12 (permalink) Old 03-24-2010, 07:43 PM
There are wheels with brown and gray pad that will cut the pits out, first is to chemically clean the oxide with something like truck wash acid or oven cleaner - both are not kind to skin! White or green dish scrubbies may be enough to cut it, white on a power wheel will often do the prep for polish. I tried a microfiber bonnet with paint polish on frontrunners and it looked very good
81 Isuzu /C223na, 5spd
keydl is offline
post #5 of 12 (permalink) Old 03-24-2010, 08:58 PM
Nitelord's Avatar
Images: 2
Adams Metal polish is good, but won't remove the pitting. Once the pitting is repaired, our polish will keep it looking awesome. The Meguiar's product is also very good. I believe they have several levels of product. Read the labels...
2005 Ford F350 dually sb, wrapped in Black
Nitelord is offline
post #6 of 12 (permalink) Old 03-24-2010, 10:59 PM
mattsn's Avatar
Originally Posted by Nitelord View Post
Adams Metal polish is good, but won't remove the pitting. Once the pitting is repaired, our polish will keep it looking awesome. The Meguiar's product is also very good. ]I believe they have several levels of product..
yeah i hate all those levels. i figure make a good product to stand against the competition and leave it alone. I had a mquiers rep try to explain all that level stuff to me and it made no sense really.
mattsn is offline
post #7 of 12 (permalink) Old 03-25-2010, 05:19 AM
Resident GINGER
CFRO's Avatar
Send a message via MSN to CFRO
Here is what I have had to do in the past a couple times.
08 Ranger Grabber Orange. XLT 4x4 5 Speed Manual Super cab. Sirius. Silvana 9007 and 9415's. Amsoil 0w30 (Mileage Maximizer). Dee Zee Powder Coated Tool Box (PEELING). Dual 3' Fire Sticks. Cobra 75 X.
94 F-350 CC LB 5 -Speed. 4.10's. MBRP. Single Mass. 265/75's on 16x8's. Uniden CB. 3' Firestick.
Single club # 61
CFRO is offline
post #8 of 12 (permalink) Old 03-25-2010, 02:31 PM
The sand paper rack has 24 grit through 1600 grit.
It is the same with polish, some start with rubbing compound and some start with very fine polish. Change the agressiviness by dilution on most products.
keydl is offline
post #9 of 12 (permalink) Old 04-01-2010, 05:37 AM
bmoeller's Avatar
If the pitting is deep, sanding will be the ONLY option to get it out. Then polish after it is smoothed out.
Acid aluminum cleaner will be needed if the oxidation is bad enough. Helps to use a tiny bit at a minimum to take the top layer off.
For heavy cutting, I use a buffing wheel similar to this one-
High cut, low shine. Use 3M buffing compound for heavy cutting. It is like liquid sandpaper.
After using that, I use a different buffing wheel with a low cut, high shine and Zephyr Pro 40 polish. Sometimes use the White diamond polish as well.
I don't care what kind of polish you use. If you don't use the correct polishing wheel/buff for the job, you won't get the results you are looking for. Or, if you do, it WILL take a LOT more time and elbow grease to get it done.
"Obama = Hoax and Chains"
bmoeller is offline
WasGas (04-01-2010)
post #10 of 12 (permalink) Old 04-01-2010, 05:44 AM
& amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; quot ;Mis s me yet&a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;q uot; George Bush
WasGas's Avatar
That is some good info
WasGas is offline
The Following User Says Thank You to WasGas For this addition to TDG:
Scooby (10-26-2010)
The Polish Cow......Funny Spike 64 The Parking Lot 3 01-26-2009 11:31 PM
Gravel pitting lyrical_assasin General Ford Truck and Excursion 2 04-18-2008 04:25 PM
Motol Metal wheel owners.....pitting problem? rtm038 General Ford Truck and Excursion 5 04-12-2008 01:47 AM
Adam's polish POWER STROKE 99 The Detailing, Paint & Bodyshop 13 01-19-2008 01:10 PM
Adams Polish BROKER The Parking Lot 17 04-13-2006 01:20 PM
