Lexan Window Polish - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ryanihw350, this thread has received 4 replies and been viewed 2082 times.
post #1 of 5 (permalink) Old 05-12-2010, 01:48 AM Thread Starter
1stGenpuller
ryanihw350's Avatar
Lexan Window Polish
Is there anything to get scratches out of Lexan windows. Out logging equipment window are getting scratched pretty good and is getting hard to see out of when the sun hits it.
I was wondering how the Headlight polish would work on it.
Street Pulling Project: 1992 Dodge W-350 SRW 4x4 South Bend DD 3600 Pulling Clutch, Superlift 6 in lift,Ladder Bars Engine: 1st Gen Cummins, II SPS 66 Turbo, BHAF, VE Pump Maxed, 2nd Gen Lift Pump,366 Gov spr, Custom Injectors.
Daily Driver: 2000 Ford 7.3 CC 4x4 DP-Tuner
www.libertyantiquetractorpull.com
SMOKIN' 2010
ryanihw350 is offline
post #2 of 5 (permalink) Old 05-12-2010, 11:55 PM
mattsn's Avatar
you could always try a small spot with head light polish. there are some types of plastics that you cant use that on. not sure if lexan is one of them. there is also a type of polish made for motorcycle windshields that might work also. harley or s100 would probably be your best choices for that.
mattsn is offline
post #3 of 5 (permalink) Old 05-13-2010, 12:32 AM
bushpilot's Avatar
check out griots garage, meguiars or Adams polish <Adams is a sponsor of this forum>.
depending on how bad the haze / scratches are you may have to make MULTIPLE passes
and you likely will have to use increasingly finer grades of cut until all the scratches are
gone.
Don R.
Truck Audio,
bushpilot is offline
post #4 of 5 (permalink) Old 05-13-2010, 01:36 AM Thread Starter
1stGenpuller
ryanihw350's Avatar
thanks for the info
SMOKIN' 2010
post #5 of 5 (permalink) Old 05-17-2010, 07:41 AM
Novis makes 2 polishes for polycarbinate, the coarse will do for stuff in the shade and the fine requires skill to finish.
Some toothpaste is good, some not consistant.
If it is not coated, it can be finished with a flame polish after the fine Novis. Once agin practice first.
If you have not finished plastic it may be cheaper to get a sheet at the plastic supply house, a crosscut skillsaw blade and the specialty drill bit will work well.
Spray with dilute Dawn dishwashing detergent to kill the static electricity when the paper comes off, wash with a flag tipped brush, NEVER use anything with amonia in it and the only wax that seems to work is Protectal - $8 in the camper isle at Walmart.
The uncoated scratches very easy, the coated is close to acrylic. Acrylic will shatter the same as glass but in 1/8 in or thicker polycarbonate is UL listed as burglar resistant, it tears unless it is to old - seems about 10 years.
81 Isuzu /C223na, 5spd
keydl is offline
which to use first? polish or wax... kidn1980 The Detailing, Paint & Bodyshop 7 05-04-2011 04:51 PM
Needs polish and paint 379Longhood Heavy Duty Rebuilds / Rides 8 12-01-2010 05:43 PM
Adam's polish POWER STROKE 99 The Detailing, Paint & Bodyshop 13 01-19-2008 01:10 PM
Polish joke LargeCar The Parking Lot 3 10-10-2006 07:08 PM
Adams Polish BROKER The Parking Lot 17 04-13-2006 01:20 PM
