speed sensor A - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by vcassens, this thread has received 2 replies and been viewed 6817 times.
post #1 of 3 (permalink) Old 06-18-2010, 08:59 PM Thread Starter
vcassens's Avatar
speed sensor A
I have a p0500 it is speed sensor A so my ? is witch sensor is speed sensor A thanks
2004 ford F350 6.0L 6 speed manual,SCT live wire,south bend double disk clutch,short throw shifter fx4. Costome exhaust 4 inch turbo back to 5" homade stacks, banjo bolt mod, shimed regulator,custom leveling kit (not blocks) and air lift air bags with onbord air suply TRADED FOR
2006 ford F 250 Amarillo 4" turbo back other than that stock for now
singles club #206
bomb squad #67
Ridin' Dirty Club #65
vcassens is offline
post #2 of 3 (permalink) Old 06-19-2010, 03:27 AM Thread Starter
vcassens's Avatar
any one I need to get this fixed thanks
singles club #206
bomb squad #67
vcassens is offline
post #3 of 3 (permalink) Old 06-20-2010, 12:36 PM
harry6.0's Avatar
I found this info, even though its for a later yr model. Sounds like its the rear diff speed sensor. Very common to go bad on some fords.
This article supersedes TSB 05-11-12 to update the vehicle model years and Service Procedure. ISSUE:
Some 2005-2006 F-Super Duty vehicles may exhibit an ABS light on and possible diagnostic trouble codes (DTCs) C1175, C1236, P0500 and/or P0503. This condition may be due to faulty vehicle wiring, a failed wheel speed sensor or "vehicle speed sensor" (VSS) tone ring damage inside the rear differential case. The base brake system will continue to function as normal.
ACTION:
Follow appropriate Service Procedure based on DTC.
SERVICE PROCEDURE
P0500 And/Or P0503
P0500/0503 is set by the PCM when the VSS signal from the ABS module is missing. If the vehicle has DTC P0500/P0503 in the PCM, and the vehicle has ABS DTCs, check ground 105 and the ABS fuse (mini fuse #11). C1175
Harry
harry6.0 is offline
vcassens (06-20-2010)
Possible Speed Sensor maxxis_mudder 2003-2007 6.0L Power Stroke 1 02-26-2008 01:48 PM
speed sensor katzer 1994-2003 7.3L Power Stroke 1 02-18-2008 11:04 PM
speed sensor tukara General Ford Truck and Excursion 0 05-04-2007 06:41 PM
speed sensor sprman 2003-2007 6.0L Power Stroke 1 10-21-2006 05:29 AM
Speed Sensor fuzzys69 1994-2003 7.3L Power Stroke 4 05-22-2006 03:58 AM
