New flash - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lubbockguy1979, this thread has received 5 replies and been viewed 1447 times.
post #1 of 6 (permalink) Old 06-22-2010, 04:46 PM Thread Starter
illadvised and dangerous
Lubbockguy1979's Avatar
Send a message via Yahoo to Lubbockguy1979
New flash
So on one of the sites I read I came across a post talking about a new ford flash that limits the injectors leaving his tuning device unable to up the power is once had. I believe I'm about to be taking mine in to check out the oil cooler. Which will lead to them flashing my truck. Will this be a issue? I assume they are doing this in the ficm but onlyb read one instance of it and the guy's tuner was a diablo predator
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
isspro egt/boost/trans/fuel
as well as pretty much
everything else
Lubbockguy1979 is offline
post #2 of 6 (permalink) Old 06-23-2010, 12:45 PM
harry6.0's Avatar
I kinda doubt it will effect an sct tuner, especially custom programs for your strategy. Of the ford flashes out there, the one for the 2003-early 2004 trucks that eliminates/infers the ebp sensor reading could have an effect on canned programs or inline devices that used the ebp sensor for tuning. I believe any tuning can be fixed on the 6.0 including the ficm's these days as the 6.0 has been disected thoroughly at this point. I wouldn't worry to much. Harry
harry6.0 is offline
post #3 of 6 (permalink) Old 07-01-2010, 02:57 AM
Trip's Avatar
custome tunes I belive will be effected by a new flash, but you should be able to ask ford not to update to the latest software if your out of warrenty and have them reflash with the older flash
WALNUT (anti-ACORN) member#23
Trip is offline
post #4 of 6 (permalink) Old 07-01-2010, 03:08 AM
strokin6L's Avatar
i don't think you can have them update to a older flash. If they flash it...it will be the newest flash. You just can't pick which flash you want.
strokin6L is offline
post #5 of 6 (permalink) Old 07-25-2010, 10:49 PM
NuttyProfessor's Avatar
Just a strategy change, nothing to block out a tuner if he/she has the new template!
NuttyProfessor is offline
post #6 of 6 (permalink) Old 08-28-2010, 01:54 AM Thread Starter
looking forward to the new tunes mike.
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
everything else
To flash or not to flash, that is the question... 444turbodiesel 2003-2007 6.0L Power Stroke 5 05-22-2009 08:19 PM
Flash 08-25-7 Demolition 2008-2010 6.4L Power Stroke 3 12-29-2008 09:58 PM
2005...To Flash or not To Flash tstc 2003-2007 6.0 Tuner Forum 9 03-21-2008 11:03 PM
Flash Help imported_newtodiesel 2003-2007 6.0L Power Stroke 9 12-17-2007 07:26 PM
flash or no flash is the ? Bcarriveau 2003-2007 6.0L Power Stroke 15 09-13-2007 06:31 AM
