Ground ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Tweez, this thread has received 10 replies and been viewed 2468 times.
post #1 of 11 (permalink) Old 07-12-2010, 01:48 PM Thread Starter
Tweez's Avatar
Ground ?
I have a 2004 F250 with the Bully Dog triple dog with the outlook monitor,
the trouble that im having is that the monitor will work one time then not the
next,i have sent it in to bully dog spent a $100 they said their was nothing wrong,they said i must have a bad ground some were,im in a sling now for 8 weeks and i cant climb around under the truck to look i think i will have my son look,any ideas where to start.
Tweez is offline
post #2 of 11 (permalink) Old 07-12-2010, 04:25 PM
lilpooh's Avatar
Start with the battery cables, and work your way thru the entire engine compartment. Look for chafed or loose wires. I'm not sure where the Bully dog gets pluged in at, but if it's at the OBD port or the PCM, check thier also.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #3 of 11 (permalink) Old 07-12-2010, 05:42 PM Thread Starter
Tweez's Avatar
Thanks it does plug in the OBD ill start looking their.
Tweez is offline
post #4 of 11 (permalink) Old 07-15-2010, 02:54 PM
when you say does not work do you mean it will not turn on at all? or it just does not back light?
Blackcloud556 is offline
post #5 of 11 (permalink) Old 07-15-2010, 03:45 PM Thread Starter
Tweez's Avatar
The monitor period they fixed the back light but about two weeks after that
it just wouldnt come on, sometimes after you would shut off the truck and
restart it ,it would work, as i said they said that is was probably a ground in my truck i think im being yanked.
Tweez is offline
post #6 of 11 (permalink) Old 07-16-2010, 02:36 PM
Bigking's Avatar
Sell it and get an SCT, Problem solved.
05' F-250, Harley Davidson #2993, True Blue
SCT X2 programmer (innovative tuned), MBRP 4in turbo back SS Cool Duals, Gutted Cat, S&B cold air intake, 2" front 1" rear lift, 325x60x20 Nitto Terra Grapplers, Stock Harley 20" rims, Line X, 20% tint all around, Alpine Linear Sub system, 4k Sylvania Silver Star lights, Zoo Dad mod, line of fire by Recon, ARP head studs, RCD EGR delete, new heads, new Turbo, dual bilstein steering stabilizers, bilstein 5100 shocks all 4 corners, truxedo bed cover, Amsoil. U.S.C.G
Bigking is offline
post #7 of 11 (permalink) Old 09-07-2010, 11:06 PM
I have the 40500 Triple Dog Downloader. I have had trouble with it from the first day I bought it about 3 years ago. It will always power up and show the main menu, however, I have had intermittent trouble:
* downloading one of the tunes, either tow, Crazy Larry or mileage
* restoring the stock tune
* reading and/or clearing DTC's and MIL
I've emailed Bully Dog on 3 separate occasions over the last 3 years, only to find out that the 40500 is not upgradable, they will not support sending it back for repairs or upgrading it and, at this point, will not return my emails.
06' F250 Mods:
Performance related:
-K&N E-0780 Air Box, ZooDad Mod
-Garrett Powermax Turbo, CFM+ Smallmouth Intake Manifold
-Blue Fuel Pressure Spring, Large fuel lines from pressure regulator to heads
-MBRP 4" Turbo back exhaust; cat installed
-SCT SF3 Tuner w/SRL custom tunes from Matt at GearheadAutomotivePerformance.com
Reliability Mods:
-Refurbished 50 volt FICM, Eliminated STC fitting, upgraded stand pipes and dummy plugs, Bulletproof Diesel EGR cooler, upgraded turbo oil supply and drain
-Oil change rotation; 5k-5W40/5k-15W40/5k-15W40
--Rotella T5 or Valvoline Blue Extreme 5W40, Rotella or NAPA 15W40, Archoil 9100 friction modifier (16 ounces to crank case; 10 ounces to each differential)
--2/3 Qt. tcw3 2 cycle oil per tank Power Service (5 oz. Stanadyne every tank)
-Cooling system flush with Restore and VC-9 @ 73,000 miles w/new thermostat
-Eliminated clunk while sitting at a light (75,000 miles); Lubed rear drive-shaft spline with Ford lubricant; Symptom returned at 100,000 miles...re-lubed at 112,000 miles....wow!! it's so smooth again.
Miscellaneous:
-1/2" shim on carrier bearing mount
-Batteries:
--Original Motorcraft lasted 4 1/2 years
--AutoZone Duralast Gold lasted less than 3 years
---(with 2/0 cables between + terminals)
--Still on 2nd set of Autozone Gold (replaced free)
-Alternator:
--DC Power 185 amp
Future Mods:
-Teflon sway bar bushings
-Moog Ball Joints (originals seem to be holding tight at 108,000 miles; it's just a daily driver, so this seems to make sense)
-Cooling system filter
-OEM HG/ARP studs
bustedknuckles is offline
post #8 of 11 (permalink) Old 09-10-2010, 04:04 AM
Have you tried calling tech support at all?
If you would like to send it in for repair email me at [email protected] and ill get you taken care of.
post #9 of 11 (permalink) Old 09-17-2010, 09:58 PM
Let it all Ride
Eazydeezy's Avatar
I was wondering when somebody was gonna pipe off with this comment.
Dominic
Eazydeezy is offline
post #10 of 11 (permalink) Old 09-25-2010, 01:29 AM
LiftedBlackHD's Avatar
Funny you mentioned it. Mine works but it wont let me toggle to any of the options.
04 F250 SC LB
SCT by DJ
05+ elbow
8" Icon Lift
20" KMC Rockstars (Black)
38x15.50 Toyo M/T's
Zoodad mod
High-idle mod
Straight Piped
CCV mod
Dieselsite coolant filtration
Recon Led's
LiftedBlackHD is offline
700 to the ground.... pblankenship Medium and Heavy Duty 5 09-02-2009 04:24 PM
power to the ground dangerous196 5.9L Cummins 12 Valve (1994-1998.5) 4 09-30-2007 11:53 PM
375hp To The Ground cumminspride 5.9L Cummins (Pre 1994) 11 09-09-2007 01:57 AM
Fire on the ground! TriGuy The Parking Lot 11 07-28-2007 05:05 PM
Where can I get a good ground? CBSuperduty 2003-2007 6.0L Power Stroke 3 11-23-2005 07:16 PM
