Tuning Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mbm450, this thread has received 28 replies and been viewed 3952 times.
post #1 of 29 (permalink) Old 07-20-2010, 01:58 AM Thread Starter
Send a message via Skype™ to mbm450
Tuning Question
When you have a 6.0 tuned with no head studs, is it the boost that ultimately blows the head gaskets or is it the pressure made from the extra fuel being put into the motor and faster rpm's ? I have an 06' that has no head studs but is tuned, I am just curious if there is a difference in how the truck will hold up with a stock head configuration if you don't always put your foot to the floor. Or is it just an inevitable problem you are gonna have........
Thanks, Brad
mbm450 is offline
post #2 of 29 (permalink) Old 07-20-2010, 04:09 AM
********* and Mafia #90
Bcarriveau's Avatar
Cylinder pressure is what lifts the heads
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
The Following User Says Thank You to Bcarriveau For this addition to TDG:
mbm450 (07-20-2010)
post #3 of 29 (permalink) Old 07-20-2010, 02:32 PM
harry6.0's Avatar
More power=higher pressure no matter how its achieved. Pulling a higher gear with added power/tuning, where it pulls like a frieght train puts the most strain on the head bolts. Its a gamble even running stock with these trucks, some can run tuned for all there life without popping the gaskets. Everyone drives there trucks differently, but I would say its possible to run tuned and not have an issue, if the tuning is right for the driving style, but the risk factor is increased. Harry
harry6.0 is offline
mbm450 (07-20-2010)
post #4 of 29 (permalink) Old 07-20-2010, 10:37 PM Thread Starter
Yea I can see what you guys are saying. I have 221,000 miles on my 06' and it runs great still. I just put the tuner on it a couple wks ago. I kinda figured that the added fuel and more powerful combustion was more dangerous than pulling high boost. I take it that the "powerstoke" is more harmful than the "compression" stroke!! lol
mbm450 is offline
post #5 of 29 (permalink) Old 07-23-2010, 12:07 AM Thread Starter
Also, is there anyone out there who is running a tuner with stock head bolts that hasn't had any problems??
mbm450 is offline
post #6 of 29 (permalink) Old 07-23-2010, 05:57 PM
There are lots, but they are running on borrowed time. I stopped running one until I get studs put in. Depends on the power level and timing the tuner likes to use.
cartmanea is offline
post #7 of 29 (permalink) Old 07-23-2010, 08:34 PM
4cstr's Avatar
Images: 35
I loaded our tuner onto the Excursion before I added head studs. The minute I did that, she began burping coolant. I even had my tuner go very mild with the tune. We never pulled any trailers with the Ex, never got into high boost situations. We just cruised down the highway with it.
I had the EGR deleted first, but she still burped coolant. Now that the studs are done and the oil cooler replaced...not a drop has been shed since.
~Dave~
4cstr is offline
post #8 of 29 (permalink) Old 07-25-2010, 10:39 PM
NuttyProfessor's Avatar
Mostly caused by excessive timing! Of course added power does also but with good tuning added power doesn't equate to excessive issues.
Mike
NuttyProfessor is offline
post #9 of 29 (permalink) Old 07-30-2010, 12:58 AM
allstarsixo's Avatar
High CP's!...... In my 2007 the trans tuning and excessive timing killed the head gaskets. The truck would lock the TC and not down shift and the damn thing would puke so bad cars behind me would have to turn on there windshield wipers. It would do it with low boost and low RPM's every time. Be carefull with the custom tunes and make sure they dont get all there power from the timing.... Excessive timing and locked TQ @ low RPM's = High as hell CP's....
Lonnie
allstarsixo is offline
post #10 of 29 (permalink) Old 07-30-2010, 01:47 AM
I've ran a bullydog on all power settings except crazy larry for 165K miles so far with no head gasket issues. I do have the EGR unplugged and a 4" t-back.?
RatherBNtheWood is offline
New engine build/ Tuning question Klutch 1994-2003 7.3L Chips & Tuners Forum 2 05-01-2009 11:52 PM
Tuning question HeffPsDiesel 1994-2003 7.3L Chips & Tuners Forum 10 02-19-2008 12:07 AM
07 LBZ tuning help blksmok LBZ & LLY Tuner Forum 6 07-04-2007 10:52 PM
Question about Live EFI tuning on a dynamometer CellFishRacing 2003-2007 6.0 Tuner Forum 5 06-09-2006 02:54 PM
Another SCT tuning question.... htsht 2003-2007 6.0L Power Stroke 29 10-16-2005 06:21 PM
