New injectors - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by awhotrods, this thread has received 93 replies and been viewed 16854 times.
post #1 of 94 (permalink) Old 07-25-2010, 05:43 PM Thread Starter
awhotrods's Avatar
New injectors
My 03 6.0 finally needs injectors, bad.. I'm looking at a set from RCD, not sure which set to go with at this point. My truck is relatively stock, 4" turbo back, intake & elbow, SCT X3 with ID extreme street tune, & RCD egr delete. I would like to upgrade the stock turbo at some point & add studs, but that is down the road. I also use my truck as a daily driver/tow rig. From what I have read, alot of people go with the 190's. Looking for some input as far as performance & fuel mileage changes. Any input is greatly appreciated!
03 F350 4x4 6.0 PSD
SCT X3 with Eric's Xtreme Street Tune
RCD EGR DELETE
RCD 155's
4" TURBO BACK STRAIGHT PIPED
DIESEL SITE COOLANT FILTER
ACCUFAB 05 ELBOW
STATOR REMOVED (NO ISSUES)
ZOODAD MOD
ISSPRO TRIPLE GAUGES
05 HARLEY FRONT END
08 REAR CONVERSION
awhotrods is offline
post #2 of 94 (permalink) Old 07-26-2010, 02:26 AM
SLAPS President
teamroper60's Avatar
Images: 9
I know you can turn 190's down and make them work but if you are towing much weight, I would recommend 155's. That is what I am running in my truck and I tow a 5er that weighs 14Klbs.. My EGTs are well within check (even though I still have the stock turbo). Here is a post I made after I got back from a trip to Myrtle Beach, giving an update on towing with this set up.
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #3 of 94 (permalink) Old 07-26-2010, 03:53 AM
strokin6L's Avatar
if you tow, go with josh's 155's. I've heard great results from them.
strokin6L is offline
post #4 of 94 (permalink) Old 07-26-2010, 04:58 AM Thread Starter
awhotrods's Avatar
I don't tow very often, a car trailer with a 3-4K vehicle. Although I do want to be able to tow heavier loads if necessary. So sounds like 155's would be a better "street" injector. Are there any power gains or tuning requirements when changing from stock injectors?
03 F350 4x4 6.0 PSD
RCD EGR DELETE
RCD 155's
ACCUFAB 05 ELBOW
ZOODAD MOD
05 HARLEY FRONT END
08 REAR CONVERSION
post #5 of 94 (permalink) Old 07-26-2010, 05:51 AM
SLAPS President
Images: 9
There is a lot of power gain........
#43
post #6 of 94 (permalink) Old 07-26-2010, 03:32 PM
1911 single stack
2fast2reid's Avatar
Thumbs up
'08 2500 GMC LMM CCSB 4wd white, 1" rear block, and level kit on 285s...Fab Four replacement bumper....EFI live/4" Diamond Eye exhaust.
'06 F-250 Lariat 4wd CC SB 6.0 white/tan on bottom, cab lights 5% tint all the way around. Sometimes a Yakima kayak rack. SCT w/Cale's tunes, BTS 5R110 tranny, Hypermax stg 1 injectors, EGR delete, 5"MBRP w/out kitty.
512/916 @ BTS. SOLD
'02 F-350 Lariat 7.3 4wd CC SRW SB white cab lights matching tint on front windows, chrome brushguard. Cale's chip, BTS 4R100, Stock charger with 1.0 non wastegated exhaust housing, and Magnaflow 4".
'02 F-250 Lariat 7.3 4wd CC SB burgundy w/tan on bottom
STOCK for now.
2fast2reid is offline
post #7 of 94 (permalink) Old 07-26-2010, 04:19 PM
strokin6L's Avatar
yes there are some power gains and there will hafta be some tune changes when going with a larger injector
post #8 of 94 (permalink) Old 07-28-2010, 01:03 AM
SSpeeDEMONSS's Avatar
check out casserly's injectors too.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #9 of 94 (permalink) Old 07-28-2010, 02:47 PM
mattsn's Avatar
How much HP gain can one expect from the 155cc injectors ?
mattsn is offline
post #10 of 94 (permalink) Old 07-28-2010, 09:02 PM
SLAPS President
Images: 9
That is going to be dependent upon the tuning... On Elite's website, they claim 155's will net a 90hp gain on stock tuning. That is also what Josh said when I was up there getting mine. He also said max'd out, they are capable of almost 500hp.
According to the SpeedTracer that came with my AE, the tow tune I am running is putting out 380.3hp/786.7ft-lbs. I don't really know how accurate the SpeedTracer is but don't doubt it is close since the truck feels stouter/quicker than it ever did on the stock injectors, even in the hottest tunes I had. This tune will literally roast my rear tires (all 4 of them) to the point they disappear in a cloud of tire smoke..
The street tune I have makes this tow tune feel like stock (I didn't try the SpeedTracer with it, so I have no numbers for it). I also have a race tune but frankly doubt it will ever be loaded since the street tune was ridiculously strong and racing is not my gig.....
#43
The Following User Says Thank You to teamroper60 For this addition to TDG:
mattsn (07-28-2010)
Looking for a set of 250 cc or bigger injectors in trade for my II 185 cc injectors mikes06lariat Ford Parts wanted 1 08-12-2009 03:52 AM
Performance Injectors Or Stock Injectors imported_Stroker01 1994-2003 7.3L Power Stroke 8 05-06-2008 05:16 PM
Injectors 6.0psd 2003-2007 6.0L Power Stroke 17 01-17-2008 01:06 PM
new injectors comanchejoe 7.3L and 6.9 IDI (Pre 1994) 7 01-06-2008 11:57 AM
DIY-Injectors ckbed 1994-2003 7.3L Power Stroke 11 04-24-2007 05:08 PM
