6.0 Valve Seats ????? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ChrisSheerman, this thread has received 28 replies and been viewed 15280 times.
post #1 of 29 (permalink) Old 08-07-2010, 05:06 AM Thread Starter
ChrisSheerman's Avatar
I was just reading the article in this months four wheeler magizine. They had bullet proof diesel go through a 6.0 and fix all the weak points. I've never herd of it on a forum site. They said that the 6.0 heads have junk valve seats that crack easy they were working on a 6.0 with just 40k on it and they were finding cracks in the the seats. are the valve seats really that bad????
2005 Ford F250 6.0 auto 3.73 srw XL package crew cab, air lift air bags, remote start, CFM intake elbow.
ChrisSheerman is offline
post #2 of 29 (permalink) Old 08-07-2010, 05:54 AM
harry6.0's Avatar
Thats the first I've heard of them being a problem area issue. I would imagine some may have cracks, but if it was a real cronic problem area you would hear alot more about it. I wouldn't lose any sleep over it. If the heads are coming off for headgaskets, its always a good idea to have the heads checked and pressure tested and resurfaced. Harry
harry6.0 is offline
post #3 of 29 (permalink) Old 08-07-2010, 08:38 PM
Yeah, I read that article... I'm not too concerned with it. The author of the article did'nt say so but I think the truck (2004) they were using had been subjected to some out of the box sloppy tuning and lack of maint. Towing with an out of the box (canned) tune with no pyro installed or no respect for egt's could bring about head issues...
260" 1998 379/127 63" uni-bilt/ultracab W 1,040,000
1lw [email protected]/1850 In-framed at 850,000
Rtlo18b/3.42 46,000 Rockwells
2005 f-350 26 in Flat-top 4X4 DRW Lariat 6.0T/S ARP Studs,EGR Gone by RCD,SCTed by innovative, Dualed by MBRP,Tired by BFG
2004 f-250 CCSB Lariat 5.4 4x4
1985 F-250 4X4 6.9 all Fuel T-19
CowTruck is offline
post #4 of 29 (permalink) Old 08-07-2010, 10:40 PM Thread Starter
I'm glad you guys dont feel theres a big problem with the valve seats. I was worried cause at some point I want to put on some studs but I plan to do it one at a time to save on the down time of my truck. If there was a big problem with these seats I was thinking I'd end up learning more about working on a 6.0 than I was planning to. What is the worst thing about pulling the heads off completely anyway I was thinking the injectors would scare me the most don't want to mess those up. but then theres the push rods and rocker arms but from what i've been reading it doesnt even look like they have adjusters you just bolt them back on. Is that right? well thanks for helping with keeping from being to worried about the valve seats.
post #5 of 29 (permalink) Old 08-09-2010, 11:43 PM
I Wanna Go Fast!
brentos's Avatar
yes its a known problem...90 percent of 6.0s that do headstuds have cracked heads... problem is hardened seats dont even solve the problem always...couple of guys on other forums have cracked hardened ones...So yes guys its VERY common....ive had two sets of cracked ones myself (first time i did studs and when i tore it apart this year to build the motor they were cracked again)
brentos is offline
The Following User Says Thank You to brentos For this addition to TDG:
harry6.0 (08-10-2010)
post #6 of 29 (permalink) Old 08-09-2010, 11:47 PM
Slacker
carlson158's Avatar
Yep, it's VERY common, but never checked when a truck is brought in for head gaskets. Even the 6.4L guys are having problems with their cracks... Or cracks in their heads...
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit)
Engine Mods:
ARP studs
Fluidampr
CCV Reroute
4" MBRP Exhaust
S&B Cold Air Intake
Bypass Coolant Filter
BulletProof EGR Cooler
Garrett PowerMax Turbo
Dieselsite Intercooler Boots
SCT w/ Custom Tunes (DJ's, Innovative)
BulletProof Oil Cooler System w/ Bypass Filter
Gogo Diesel Direct Drive Solenoid
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
18" MotoMetal 950's wrapped in 33" ProComp Extreme AT's
carlson158 is offline
post #7 of 29 (permalink) Old 08-10-2010, 02:03 AM
But the question is, do the minor cracks cause a performance or reliability issue? We have done quite a few stud jobs (60+) and have only had 5 heads cracked to the point that they were unusable. Most of the time the heads have to be replaced because of fuel in the coolant in my experience. fwiw I'm no expert just a greasemonkey
bigdaddy60 is offline
post #8 of 29 (permalink) Old 08-10-2010, 03:27 AM
fordsuperduty01's Avatar
Almost all the ones I have done are cracked between the glow plug hole and the valve seat. Most of the time replacing the injector cups takes care of the fuel in the coolant.
2005 F-250 6.0L King Ranch FX4. 125k miles, Edge Platinum, EGR delete, MBRP turbo back exhaust without cat, an 03 turbo, and 4.30 gears.
A.S.E. Master certified automotive and light duty diesel technician.
fordsuperduty01 is offline
post #9 of 29 (permalink) Old 08-10-2010, 04:03 AM
Slow 6.0
the 6.0 heads can crack and it can happen anywhere on the head. that is why the heads need to be checked before being reused.
2006 F350 XLT 4x4
SICKS-O is offline
post #10 of 29 (permalink) Old 08-10-2010, 05:52 AM Thread Starter
So where is a good place to send heads to get checked any ideas what it costs to get checked or how much it costs to get the new seats put in?thanks for the info guys. this still bites though didnt international do any thing right with the 6.0???
Valve Seats EB.Bldr 5.9L Cummins (2003-2007.5) 4 01-18-2009 03:48 AM
front lariat bucket seats/jump seats for sale Darsey715 Whats Been Sold 3 03-15-2008 06:25 PM
Air shutoff valve and 3 way fuel valve '05Supersmoker Sled Pulling 2 02-05-2008 12:23 AM
cummins 60 lbs valve springs 12 valve imported_machine2 Whats Been Sold 0 05-08-2007 12:58 AM
1998 24-valve compared to 12-valve Michael 5.9L Cummins (1998.5-2002) 1 06-28-2006 05:22 PM
